VLAN Over bridge
Hello. I have seen vlan configurations created directly on a bridge and others over an ethx interface. Does this have any performance advantage? is it better to create it on a bridge if you have to use several ethx interfaces as trunks?
One has to use bridge for one main reason (and there are a few minor reasons that are somehow advenced and I’m not going to mention at this opportunity): if you want to create a L2 (ethernet) network from multiple ports (can be ethernet interfaces, wireless interfaces, EoIP interfaces and a few more types). Bridge then moves frames between member ports without regard to higher layers (L3 is IP, L4 is TCP or UDP, …).
Essentially bridge is something like an ethernet switch.
Now, if you created a bridge and added a few interfaces to it, then you don’t configure anything else directly on those interfaces (not VLANs, not IP addresses, not PtP tunnels, nothing). You use bridge interface for that.
A good explanation of different bridge personalities.
KISS, using vlans, then use vlans for all subnets, leave the bridge to bridging only.
