Vlan over wireless with Nstrem can it be
Hi all,
If any one can help me I have like 12 wireless antenna connected to switch then one antenna from switch goose to my office as ptp link then the antenna in my office is connected to a MT server connected to ads pppoe ,all is ok but some times I have issues in the link quality so I want to use vlan on some critical links
My setup for wireless is below:
Bridge for wlan1 and ether1 ,ap-bridge Wds enabled on bridge1 nstream enabled and I use ip address only for ether interface
Waw no one around
helow any one there
it looks like that im alone in the moon.
:laughing:
I know it is a major vacation time here in the US right now. Not sure where everyone else is in the world though.
I think you can not do it because you are would be adding a VLAN to a bridge which would defeat the general setup of what you have. If there was another option like a " VLAN bridge" then I think everything would work but unfortunately there is not. I think the problem is placing this value with an interface group. Please someone correct me if I am wrong but I have tried to setup similar things in the past with no go. What you may be able to do is set up a personal VWLAN (Virtual AP) and add all new encryption IP address and the like. This should help you out since you already have a WDS AP setup.
-Sincerely,
DesertAdmin
