Hello all
I’m trying to setup a Mikrotik RB951G-2HnD with hybrid ports, I’m almost there but I’ve got a couple of questions about prioritization
Scenario is as follows
- ether1 will be gateway
- All other ethernet ports will be used to connect either PCs or VLAN capable devices (hybrid ports)
I’ve setup a VLAN with id 20, I want that VLAN to have priority “7” and the rest untagged network to have priority “0”, as far as I understand all non tagged traffic is already tagged “0” so I suppose that what’s left is to set the VLANs priority but I’m not clear how to do that.
The idea is the following: We have this VoIP phones that will be configured to use vlan id 20 and then we’ll connect PC’s to those phones, PCs will get untagged connection
VLAN id 20 has a 172.16.20.0/24 network
and untagged traffic has a 192.168.88.0/24 network
So far I was able to achieve almost everything except for priority, I’m not quite clear on how to do it, this is my configuration so far
add admin-mac=D4:CA:6D:7E:A8:65 auto-mac=no mtu=1500 name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 mode=ap-bridge \
ssid=MikroTik-92E969
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add comment="" interface=bridge-local l2mtu=\
1594 name=vlan-20 vlan-id=20
set vlan-20 comment=""
add name=dhcp ranges=192.168.88.100-192.168.88.200
add name=pool-vlan-20 ranges=172.16.20.30-172.16.20.250
add address-pool=dhcp disabled=no interface=bridge-local lease-time=8h name=\
default
add address-pool=pool-vlan-20 disabled=no interface=vlan-20 lease-time=8h \
name=dhcp-vlan-20
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add independent-learning=no ports="ether2-master-local,ether3-slave-local,ethe\
r4-slave-local,ether5-slave-local,switch1-cpu" switch=switch1 vlan-id=20
add address=192.168.88.1/24 comment="default configuration" interface=\
ether2-master-local network=192.168.88.0
add address=172.16.20.1/24 comment="vlan-20 address" interface=vlan-20 \
network=172.16.20.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
no interface=ether1-gateway
add address=172.16.20.0/24 comment="vlan-20 Network" dns-server=\
8.8.8.8,208.67.222.222 gateway=172.16.20.1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" disabled=yes \
in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid disabled=yes
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=ether1-gateway
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/romon port
add disabled=no
/system clock
set time-zone-autodetect=no time-zone-name=US/Pacific-New
/system clock manual
set time-zone=-06:00
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
Any help will be greatly appreciated
