Good day, i’m having some issues using vlans on this device, scenario is like this:
2 x CRS326-24S+2Q+, bridge with vlans enabled, trying to get vlan30 tagged between switches(uplink sfpplus24) and untagged on port sfpplus23.
/interface bridge print
0 R ;;; defconf
name=“bridge” mtu=auto actual-mtu=1500 l2mtu=1584 arp=enabled
arp-timeout=auto mac-address=08:55:31:04:A6:71 protocol-mode=mstp
fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m
priority=0x8000 max-message-age=20s forward-delay=15s
transmit-hold-count=6 region-name=“” region-revision=0 max-hops=20
vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all
ingress-filtering=no dhcp-snooping=no
/interface bridge vlan print
Flags: X - disabled, D - dynamicBRIDGE VLAN-IDS CURRENT-TAGGED CURRENT-UNTAGGED
0 bridge 30 sfpplus24_UPLINK sfpplus23_DEVICE
sfpplus23_DEVICE has pvid 30.
/interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offloadINTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
30 H ;;; defconf
sfpplus23_DEVICE bridge yes 30 0x80 10 10 none
Configuration is the same on both switches, uplink is up
UPLINK sfpplus24 between switches, SM fiber
/interface ethernet monitor sfpplus24_UPLINK
status: link-ok
auto-negotiation: done
rate: 10Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-connector-type: LC
sfp-link-length-sm: 10km
sfp-vendor-name: Mikrotik
sfp-vendor-part-number: S+23LC10D
sfp-vendor-revision: A
sfp-vendor-serial: STST23183600169
sfp-manufacturing-date: 18-09-15
sfp-wavelength: 1270nm
sfp-temperature: 43C
sfp-supply-voltage: 3.302V
sfp-tx-bias-current: 35mA
sfp-tx-power: 1.518dBm
sfp-rx-power: -0.175dBm
eeprom-checksum: good
eeprom: 0000: 03 04 07 20 00 00 00 12 00 01 80 06 67 00 0a 64 … … …g..d
0010: 00 00 00 00 4d 69 6b 72 6f 74 69 6b 20 20 20 20 …Mikr otik
0020: 20 20 20 20 00 00 00 00 53 2b 32 33 4c 43 31 30 … S+23LC10
Device sfpplus23, RJ45 10GB module
interface ethernet monitor sfpplus23_DEVICE
status: link-ok
rate: 10Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full
link-partner-advertising: 1000M-full,10000M-full
sfp-rx-loss: no
sfp-tx-fault: no
sfp-connector-type: RJ45
sfp-link-length-copper-active-om4: 1m
sfp-vendor-name: MikroTik
sfp-vendor-part-number: S+RJ10
sfp-vendor-revision: 2.16
sfp-vendor-serial: AF9403E2B711
sfp-manufacturing-date: 20-04-07
sfp-temperature: 66C
sfp-supply-voltage: 3.305V
sfp-tx-bias-current: 0mA
eeprom: 0000: 03 04 22 00 00 00 00 00 08 00 00 06 67 00 00 00 .."… …g…
0010: 00 00 01 00 4d 69 6b 72 6f 54 69 6b 20 20 20 20 …Mikr oTik
0020: 20 20 20 20 00 00 40 20 53 2b 52 4a 31 30 20 20 ..@ S+RJ10
0030: 20 20 20 20 20 20 20 20 32 2e 31 36 05 00 00 b0 2.16…
On one device ip is 10.10.100.1/25, on the another one 10.10.100.2/25 and i just can’t get a ping between them. The only way when it works is tagging the sfpplus23_DEVICE with vlan30, but this works because of default vlan i think, since i don’t have any vlan enabled on any device.
I’ve had installed latest stable 6.48.1 and now 6.49beta11, same result on both versions.
