VLAN problem with ROS6rc12?
Hi guys,
I’ve experienced a weird problem… Two x86. Router A ROS5.22 - Router B ROS5.24. Connected through eth1 and VLAN ID1648. Everything works fine. They ping each others through IPs on VLAN…
On Router B installed upgrade to ROS6rc12. No more communication on VLAN… Only on eth (moved IP on eth and then the pings are ok).
Downgraded router B to ROS5.24, communication on VLAN (tested again with pings) restored.
I’ve checked configuration 3 or 4 times, and after upgrade to 6rc12, all parameters seems fine…
Is it normal?
I have same problem (x86, 1Gbit Intel).
IP on VLAN interface.
~20% packet loss.
Downgrading to 5.24 solved the problem.
