i need to make a VLAN tunnel form RB433L(Ether3) to RB750GL
both devices are over WiFi Link
on RB433 Ether1, Ether2,Wlan1 is on bridge
tried creating Vlan on Bridge1 of RB433L
created another Bridge on RB433 with Vlan and Ether3 as ports
on RB750GL created a vlan (both end shows status as R)
But from vlan of RB750 to not able to ping devices of Ether3 on RB433L
Please Help
Hi..
Here is you what you should to do..
Let call RB#1 (config)
Wireless mode ap-bridge
simple bridge technique.. like EoIP or VPLS or even more simple..
/interface bridge add name=wlan-bridge
/interface bridge port add interface=wlan1 bridge=wlan-bridge
/interface bridge port add interface=ether1 bridge=wlan-bridge
RB 750GL
add two vlan on ether1 interface that connected to wireless router
/interface vlan add vlan-id=1 interface=ether1
now you should bridge the vlan with the target ether.. for example
/interface bridge add name=bridge-squid
/interface bridge add name=bridge-switch
/interface bridge port add interface=vlan1 bridge=bridge-squid
/interface bridge port add interface=ether2 bridge=bridge-squid
/interface bridge port add interface=vlan2 bridge=bridge-switch
/interface bridge port add interface=ether3 bridge=bridge-switch
RB#2 ( config )
wireless interface mode station
/interface vlan add vlan-id=1 interface=wlan1
/interface vlan add vlan-id=2 interface=wlan1
Note( if you create EoIP interface you should add vlan on EoIP interface and if you add vpls interface you should add vlan on vpls interface istead of wlan1 interface)
this is what you need to have the correct configuration..
Please let me know if all is okay… waiting you reply
Ali Sami
