We have routerboard with
ether2 and ether3 - in bridge1
ether4 and ether5 - in bridge2
now we need special port ether6 which should be a member of both bridges, but in bridge1 as untagged default vlan (vlan1), and in bridge2 as tagged vlan2.
This is can be done very simply on a managed switch, but how to do it on Mikrotik Routerboard?
Merge bridges, add appropriate VLAN interfaces, so CPU has access to VLANs and then move your DHCP servers and IP adresse to those VLAN interfaces.What you want to do is doable with one bridge an VLANs.
Of course there’s more to it (how other ports should behave, how’s management of RB itself done, does RB device interact with any of those groups of ports, …), but this code above illustrates requirements as set forward in original post.
