Vlan Question
I tried to set up a Port based Vlan on my RB750, but as I couldn’t get it to work properly I switched to 802.1Q Tags.
Unfortunatly I have the same behaviour as with my port based Vlan Setup, as I am still able to ping from one Vlan into a different one.
Here is my Setup: (I used the standard config and only removed the slave ports)
[admin@MikroTik RB750] > /interface print
 #     NAME                             TYPE               MTU L2MTU  MAX-L2MTU
 0  R  ether1-gateway                   ether             1500  1600       4076
 1     ether2                           ether             1500  1598       2028
 2     ether3                           ether             1500  1598       2028
 3     ether4                           ether             1500  1598       2028
 4  R  ether5                           ether             1500  1598       2028
 5  R  vlan1                            vlan              1500  1594
 6  R  vlan2                            vlan              1500  1594
 7  R  vlan3                            vlan              1500  1594
 8  R  vlan4                            vlan              1500  1594
 9  R  vlan5                            vlan              1500  1594
[admin@MikroTik RB750] > interface vlan print
Flags: X - disabled, R - running, S - slave
 #    NAME                    MTU ARP        VLAN-ID INTERFACE
 0 R  vlan1                  1500 enabled          1 ether5
 1 R  vlan2                  1500 enabled          2 ether5
 2 R  vlan3                  1500 enabled          3 ether5
 3 R  vlan4                  1500 enabled          4 ether5
 4 R  vlan5                  1500 enabled          5 ether5
[admin@MikroTik RB750] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; default configuration
     192.168.88.1/24    192.168.88.0    ether2
 1   192.168.0.254/24   192.168.0.0     vlan1
 2   192.168.20.1/24    192.168.20.0    vlan2
 3   192.168.30.1/24    192.168.30.0    vlan3
 4   192.168.11.1/24    192.168.11.0    vlan4
 5   192.168.10.254/24  192.168.10.0    vlan5
 6 D 83.215.249.195/27  83.215.249.192  ether1-gateway
[admin@MikroTik RB750] > ip dhcp-server print
 #   NAME     INTERFACE     RELAY           ADDRESS-POOL     LEASE-TIME ADD-ARP
 0   default  ether2                        default-dhcp     3d
 1   dhcp1    vlan1                         dhcp_pool1       3d
 2   dhcp2    vlan2                         dhcp_pool2       3d
 3   dhcp3    vlan3                         dhcp_pool3       3d
 4   dhcp4    vlan4                         dhcp_pool4       3d
 5   dhcp5    vlan5                         dhcp_pool5       3d
On the Switch Side, I connected ether5 with a trunk Port on the Switch, and created 5 Access Ports for each vlan. Having the Router unplugged I am not able to ping any other Vlan, so the Switch should be configured properly.
What am I missing? Do I have to set a Firewall Rule?
Looking at the Wikis, it seems that there shouldn’t be any more steps necessary.
The router will route among any connected networks unless you place rules in the forwarding chain to stop it from doing so.
