vlan question
Hello there…
I am trying to look for information on the CSR and cant find much…
Is it possible to have a vlan tagged and enable dhcp only for that tag?
IE:
Wireless comes in with a vlan tag of 10.
I want that vlan to get a dhcp lease from my csr.
All others un-tagged continue as is…
Than those who have a vlan tagged I want them to go out through the CSR port #1 gateway.
I also need to enable NAT on the gateway port.
My wireless is hooked up to port 21.
CRS125-24G-1S
Firmware 6.15
RouterBoard Frmware 3.12
Thanks for the help and examples!
Regards.
any body? :slight_smile:
:slight_smile: up.
Got it all taken care thanks to a user on the irc channel.
Again thanks!!!
