I’m setting up my network from scratch with VLANs.
This is my current (WIP) configuration
# dec/02/2019 10:02:31 by RouterOS 6.45.1
# software id = GYLW-MC9Q
# model = RB4011iGS+
# serial number = AAAF0A95696C
/caps-man configuration
add country=croatia datapath.local-forwarding=yes datapath.vlan-id=10 datapath.vlan-mode=use-tag name=Config_WORK security.authentication-types=wpa-psk,wpa2-psk ssid=WiFi_WORK
add country=croatia datapath.local-forwarding=yes datapath.vlan-id=20 datapath.vlan-mode=use-tag name=Config_GUEST security.authentication-types=wpa-psk,wpa2-psk ssid=WiFi_GUEST
add name=BR1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1_UPLINK
set [ find default-name=ether10 ] name=ether10_cAP
/interface vlan
add interface=BR1 name=MANAGEMENT_VLAN vlan-id=10
add interface=BR1 name=TRUSTED_VLAN vlan-id=20
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=MANAGEMENT_POOL ranges=172.29.10.200-172.29.10.254
add name=TRUSTED_POOL ranges=172.29.20.100-172.29.20.254
add address-pool=MANAGEMENT_POOL disabled=no interface=MANAGEMENT_VLAN name=MANAGEMENT_DHCP
add address-pool=TRUSTED_POOL disabled=no interface=TRUSTED_VLAN name=TRUSTED_DHCP
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=Config_WORK slave-configurations=Config_GUEST
add bridge=BR1 interface=ether2
add bridge=BR1 interface=ether3 pvid=20
add bridge=BR1 interface=ether4 pvid=10
add bridge=BR1 interface=ether5 pvid=20
add bridge=BR1 interface=sfp-sfpplus1
add bridge=BR1 interface=ether10_cAP
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether2,ether10_cAP vlan-ids=10,20
add address=192.168.1.3/24 interface=ether1_UPLINK network=192.168.1.0
add address=172.29.10.1/24 interface=MANAGEMENT_VLAN network=172.29.10.0
add address=172.29.20.1/24 interface=TRUSTED_VLAN network=172.29.20.0
add address=172.29.10.0/24 dns-server=1.1.1.1 gateway=172.29.10.1
add address=172.29.20.0/24 dns-server=1.1.1.1 gateway=172.29.20.1
set allow-remote-requests=yes servers=1.1.1.1
add action=masquerade chain=srcnat out-interface=ether1_UPLINK
add check-gateway=ping distance=1 gateway=192.168.1.1
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=RB01
With it cAP ac is configured and I’m able to connect to the wifi and ping connected devices. There’s only one problem - I’m unable to connect to the cAP using winbox. I’m only able to connect to it using mac-telnet.
If I change these configuration options, I’m able to connect to cAP ac with winbox but the wifi does not work (wifi signal is there but when I connect to it I get an ip that I should’t have)
# Wifi works, Winbox does not
/interface bridge port add bridge=BR1 interface=ether10_cAP
/interface bridge vlan add bridge=BR1 tagged=BR1,ether2,ether10_cAP vlan-ids=10,20
# Winbox works, wifi does not
/interface bridge vlan add bridge=BR1 tagged=BR1,ether2 vlan-ids=10,20
/interface bridge port add bridge=BR1 interface=ether10_cAP pvid=10
cAP ac config
# jan/02/1970 03:02:25 by RouterOS 6.45.1
# software id = 0N34-HG05
# model = RBcAPGi-5acD2nD
# serial number = B9320A0A64A1
add name=cap_bridge
/ip hotspot profile
add bridge=cap_bridge interface=ether1
/interface wireless cap
set bridge=cap_bridge discovery-interfaces=cap_bridge enabled=yes interfaces=wlan1,wlan2
add address=172.29.10.2/24 interface=ether1 network=172.29.10.0
add check-gateway=ping distance=1 gateway=172.29.10.1
/system clock
/system identity
set name=cAPac01
Whats wrong here? How to have CAPsMAN working with the ability to connect to cAP ac with winbox?
