Hello.
And so the actual topic. Please informed, educated people to share this information. (what the team with an example please)
How to make a particular port “access”
How to make a particular port is “Trunk”
How to create vlan
How do I assign vlan 'id
How do I assign vlan 'Ip
How to set port vlan’s in the range (for example in cisco-“range”)
Perhaps more important is what the team what I may have missed.
At this point you need to understand how it works. In fact, trying to make a simple circuit. 2port - Access to the assigned vlan2, 3 port access to the assigned vlan300, 5 port trunk, and passes these two Vlan’s
I beg you to write what commands correspond to the points.
Thank you for your reply. Also, there is a Russian version of the same settings.(http://wiki.mikrotik.com/wiki/Руководства:Интерфейс/VLAN) Nevertheless, there does not describe all the items that I mentioned, namely, the most simple and intuitive, and those that are critically needed, not described. I apologize for the translation. If no problem please describe the team, I do not rule out that I chegoto misunderstood, alone is very difficult to understand without the normal notes and hints at the Russian, and not owning the English language
All available parameters are listed in the manual. What you are asking is specific configuration examples. Part of which is already covered in the manual, like creating vlan and adding ip address to vlans, trunk setup example etc.
Note that router is not a managed switch and you can’t for example make vlan ranges in RouterOS.
