VLAN routing between two or more subnets
Hi guys. Can you help me please or point to right direction where to dig. I am novice in VLANS
I got bridge with two vlans withdiferent tags and diferent subnets being managed by one rb4011
In one vlan subnet is pc connected , in other vlan subnet is ssh server.
When i try from pc make connection to ssh server i got no success where even ping between devices doesn’t work. Both devices receive successfully dhcp server ip address
No firewall rules and everything is nat masquerade.
Please help. Thank You
Post complete configuration … run /export hide-sensitive in terminal window and copy-paste the result.
I found, its just problem with ssh server vlan in that port. Wrong config tagged/untagged
Tried with another vlan, work as expected.
Thanks anyway !
