I have the following VLANs:
add name=bridge1 pvid=10 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan15 vlan-id=15
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan30 vlan-id=30
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,vlan10 vlan-ids=10
add bridge=bridge1 tagged=bridge1,vlan15 vlan-ids=15
add bridge=bridge1 tagged=bridge1,vlan30 vlan-ids=30
add bridge=bridge1 tagged=bridge1,vlan20 vlan-ids=20
With the IPs:
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.15.254/24 interface=vlan15 network=192.168.15.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
add address=192.168.1.2/24 interface=ether1 network=192.168.1.0
add distance=1 gateway=192.168.1.1
On ether1 is the Internet Router and on ether3 (VLAN 15) is a Server which provides VPN (L2TP). On the Internet Router i have a static Route 192.168.0.0 to Gateway 192.168.1.2. The Server itself is able to perfectly reach IPs in other VLANs. But if i connect with VPN to the Server, i can only reach IPs in VLAN 15. What do I need to change?
Here is the complete config:
# feb/02/2020 14:53:39 by RouterOS 6.46.2
# model = CRS328-24P-4S+
/interface vlan
/ip hotspot profile
add name=pool15 ranges=192.168.15.178-192.168.15.194
add name=pool30 ranges=192.168.30.100-192.168.30.254
add name=pool10 ranges=192.168.10.100-192.168.10.254
add name=dhcp_pool3 ranges=192.168.10.100-192.168.10.254
add address-pool=pool15 disabled=no interface=vlan15 name=server15
add address-pool=pool30 disabled=no interface=vlan30 name=server30
add address-pool=dhcp_pool3 disabled=no interface=vlan10 name=server10
add bridge=bridge1 interface=ether21 pvid=15
add bridge=bridge1 interface=ether24 pvid=30
add bridge=bridge1 interface=ether4 pvid=30
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=vlan15 pvid=\
15
add bridge=bridge1 interface=vlan10 pvid=10
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
interface=ether2 pvid=15
add bridge=bridge1 interface=ether5 pvid=15
add bridge=bridge1 interface=ether6 pvid=15
add bridge=bridge1 interface=ether7 pvid=30
add bridge=bridge1 interface=ether8 pvid=30
add bridge=bridge1 interface=ether9 pvid=15
interface=ether10 pvid=15
interface=ether11 pvid=15
interface=ether12 pvid=15
interface=ether13 pvid=15
interface=ether14 pvid=15
interface=ether15 pvid=15
interface=ether16 pvid=15
interface=ether17 pvid=15
interface=ether18 pvid=15
interface=ether19 pvid=15
interface=ether20 pvid=15
interface=ether22 pvid=15
interface=ether23 pvid=15
add bridge=bridge1 interface=ether3 pvid=15
add bridge=bridge1 interface=vlan30 pvid=30
add address=192.168.10.0/24 dns-server=192.168.1.1 gateway=192.168.10.1
add address=192.168.15.0/24 dns-server=192.168.1.99 gateway=192.168.15.254 \
netmask=24
add address=192.168.30.0/24 dns-server=192.168.1.1 gateway=192.168.30.1 \
netmask=24
set servers=192.168.1.1
/system clock
/system routerboard settings
set boot-os=router-os
