I just bought a new HAP AC2 for a friend and am creating a config on it that is similar to my HAP AC2. Basically I have created bunch of VLANs that are isolated from each other and no network traffic is allowed across VLANs, except what I explicitly allow in the Firewall rules. This config works on my HAP AC2, but for some reason the new HAP AC2 is allowing VLANs to talk to each other without any explicit rules in the Firewall. I’ve done several reviews at this point and I can’t seem to find the needle in the haystack. I’d appreciate if you can take a look at my config below and let me know where I went wrong.
I’ve testing this with connecting two computers connected to different wifi SSIDs on separate VLANs and I’m able to ping IPs from 10.0.10.x segment into 10.0.70.x and vice versa.
Thanks in advance!!
# jul/11/2020 16:17:32 by RouterOS 6.47
# software id = YX1W-QFPB
# model = RBD52G-5HacD2HnD
# serial number = B4A00C818D2A
add admin-mac=48:8F:5A:4E:D4:DD auto-mac=no comment=defconf name=BR1 \
vlan-filtering=yes
set [ find default-name=ether2 ] name=ether2-OPEN
set [ find default-name=ether3 ] name=ether3-OPEN
set [ find default-name=ether4 ] name=ether4-OPEN
set [ find default-name=ether5 ] name=ether5-WRST
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTik-4ED4E2 \
wireless-protocol=802.11
/interface vlan
add interface=BR1 name=GUEST_VLAN vlan-id=70
add interface=BR1 name=HOME_VLAN vlan-id=10
add interface=BR1 name=IOT_VLAN vlan-id=80
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=home-user supplicant-identity=""
allowed mode=dynamic-keys name=guest-user supplicant-identity=""
allowed mode=dynamic-keys name=iot-user supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge name=wlan-2-home security-profile=home-user ssid=RocketShip
add disabled=no keepalive-frames=disabled mac-address=4A:8F:5A:4E:D4:E1 \
master-interface=wlan-2-home multicast-buffering=disabled name=wlan-guest \
ssid=RocketShipGuest wds-cost-range=0 wds-default-cost=0 wps-mode=\
disabled
add disabled=no keepalive-frames=disabled mac-address=4A:8F:5A:4E:D4:E2 \
master-interface=wlan-2-home multicast-buffering=disabled name=wlan-iot \
ssid=RocketShipIOT wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/ip hotspot profile
add name=HOME_POOL ranges=10.0.10.10-10.0.10.254
add name=GUEST_POOL ranges=10.0.70.10-10.0.70.254
add name=IOT_POOL ranges=10.0.80.10-10.0.80.254
add address-pool=default-dhcp disabled=no interface=BR1 name=defconf
add address-pool=HOME_POOL disabled=no interface=HOME_VLAN name=HOME_DHCP
add address-pool=GUEST_POOL disabled=no interface=GUEST_VLAN name=GUEST_VLAN
add address-pool=IOT_POOL disabled=no interface=IOT_VLAN name=IOT_VLAN
add bridge=BR1 comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=\
ether2-OPEN pvid=10
ether3-OPEN pvid=10
ether4-OPEN pvid=10
ether5-WRST pvid=10
wlan-2-home pvid=10
add bridge=BR1 comment=defconf interface=wlan2
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=wlan-guest pvid=70
ingress-filtering=yes interface=wlan-iot pvid=80
/interface bridge vlan
add bridge=BR1 tagged=BR1 untagged=\
wlan-2-home,ether5-WRST,ether2-OPEN,ether3-OPEN,ether4-OPEN vlan-ids=10
add bridge=BR1 tagged=BR1 untagged=wlan-guest vlan-ids=70
add bridge=BR1 tagged=BR1 untagged=wlan-iot vlan-ids=80
/interface detect-internet
set wan-interface-list=WAN
add comment=defconf interface=BR1 list=LAN
add interface=HOME_VLAN list=VLAN
add interface=GUEST_VLAN list=VLAN
add interface=IOT_VLAN list=VLAN
add address=192.168.88.1/24 comment=defconf interface=BR1 network=\
192.168.88.0
add address=10.0.10.1/24 interface=HOME_VLAN network=10.0.10.0
add address=10.0.70.1/24 interface=GUEST_VLAN network=10.0.70.0
add address=10.0.80.1/24 interface=IOT_VLAN network=10.0.80.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.0.10.0/24 comment="Home Network IPs" domain=home gateway=\
10.0.10.1
add address=10.0.70.0/24 comment="Guest Network IPs" domain=guest gateway=\
10.0.70.1
add address=10.0.80.0/24 comment="IOT Network IPs" domain=iot gateway=\
10.0.80.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="Allow estab & related" \
"Allow VLANs to access router services like DNS, Winbox" disabled=yes \
in-interface-list=VLAN
invalid
add action=drop chain=input comment="Drop DNS from WAN" dst-port=53 \
in-interface-list=WAN protocol=udp
in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="DropTelnet from WAN" dst-port=23 \
add action=drop chain=input comment="Drop Telnet from WAN" dst-port=23 \
add action=accept chain=forward comment="Allow estab & related" \
add action=accept chain=forward in-interface-list=VLAN out-interface-list=WAN
connection-state=established,related disabled=yes
connection-state=invalid
connection-state=new disabled=yes in-interface-list=WAN
/system clock
set time-zone-name=America/New_York
/tool mac-server
/tool mac-server mac-winbox
