Fewi,
Here is the configursation script as is after all firewalls were removed. A bit long and intimidating for me at my level.
I have done some prelim testing of the current configuration with a different app than Iperf which I have not been able to install on my Windows so far.
Rather posting them here at this stage without comparison. I want to wait till after your feedback of the attached script and will run some more testing and forward them both then. It would make more sense to me this way.
Thank you for your interest, Fewi.
dec/10/2010 18:26:29 by RouterOS 4.2
software id =
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
comment="" disabled=yes forward-delay=15s max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"Router link to Modem" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:53:FB:43 master-port=none mtu=1500 name=ether1
speed=1Gbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"Router link to HP Procurce 1810G-24" disabled=no full-duplex=yes l2mtu=
1524 mac-address=00:0C:42:53:FB:44 master-port=none mtu=1500 name=ether2
speed=1Gbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"2nd Router link to HP Procurve 1810G-24" disabled=no full-duplex=yes
l2mtu=1524 mac-address=00:0C:42:53:FB:45 master-port=none mtu=1500 name=
ether3 speed=1Gbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"Router link to Wireless RB411A" disabled=no full-duplex=yes l2mtu=1524
mac-address=00:0C:42:53:FB:46 master-port=none mtu=1500 name=ether4
speed=1Gbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
Spare disabled=no full-duplex=yes l2mtu=1524 mac-address=
00:0C:42:53:FB:47 master-port=none mtu=1500 name=ether5 speed=1Gbps
/interface vlan
add arp=enabled comment="Mgt VLAN" disabled=no interface=ether2 l2mtu=1520
mtu=1500 name=VL-101 use-service-tag=no vlan-id=101
add arp=enabled comment="Game Consoles" disabled=no interface=ether2 l2mtu=
1520 mtu=1500 name=VL-103 use-service-tag=no vlan-id=103
add arp=enabled comment=VoIP disabled=no interface=ether2 l2mtu=1520 mtu=1500
name=VL-104 use-service-tag=no vlan-id=104
add arp=enabled comment="David VLAN" disabled=no interface=ether2 l2mtu=1520
mtu=1500 name=VL-102 use-service-tag=no vlan-id=102
add arp=enabled comment="For printer" disabled=no interface=ether2 l2mtu=1520
mtu=1500 name=VL-105 use-service-tag=no vlan-id=105
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
switch-all-ports=yes
set default authentication-types="" eap-methods=passthrough group-ciphers=""
group-key-update=5m interim-update=0s management-protection=disabled
management-protection-key="" mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key=""
wpa2-pre-shared-key=""
add add-arp=yes address-pool=static-only authoritative=after-2sec-delay
bootp-support=static disabled=no interface=bridge1 lease-time=3d name=
server1
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=192.168.104.11
add name=dhcp_pool3 ranges=192.168.103.11
add name=dhcp_pool2 ranges=192.168.102.11
add name=dhcp_pool4 ranges=192.168.105.2-192.168.105.30
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default
use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption
only-one=default use-compression=default use-encryption=yes
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment=""
direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=
0/0 max-limit=0/0 name=VoIP-SIP packet-marks=VoIP-SIP parent=none
priority=1 queue=default-small/default-small total-queue=default-small
0/0 max-limit=0/0 name=VoIP-RTP packet-marks=VoIP-RTP parent=none
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=
backbone type=default
/snmp
set contact="" enabled=yes engine-boots=27 engine-id="" location=""
time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-only boot-protocol=bootp
cpu-frequency=680MHz enable-jumper-reset=yes enter-setup-on=any-key
force-backup-booter=no
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass
word,web,sniff,sensitive,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb
ox,password,web,sniff,sensitive,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy
,test,winbox,password,web,sniff,sensitive"
add bridge=bridge1 comment="" disabled=no edge=auto external-fdb=auto
horizon=none interface=ether4 path-cost=10 point-to-point=auto priority=
0x80
add bridge=bridge1 comment="" disabled=yes edge=auto external-fdb=auto
horizon=none interface=VL-102 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=VL-101 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=VL-103 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=VL-104 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether1 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether2 path-cost=10 point-to-point=auto priority=
0x80
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=no
use-ip-firewall-for-vlan=yes
set (unknown) vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:00:0D:BC:FE:16
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.101.1/27 broadcast=192.168.101.31 comment="" disabled=no
interface=VL-101 network=192.168.101.0
add address=192.168.102.1/27 broadcast=192.168.102.31 comment="" disabled=no
interface=VL-102 network=192.168.102.0
add address=192.168.103.1/27 broadcast=192.168.103.31 comment="" disabled=no
interface=VL-103 network=192.168.103.0
add address=192.168.104.1/27 broadcast=192.168.104.31 comment="" disabled=no
interface=VL-104 network=192.168.104.0
add address=192.168.105.1/27 broadcast=192.168.105.31 comment="" disabled=no
interface=VL-105 network=192.168.105.0
/ip dhcp-client
add add-default-route=yes comment="" default-route-distance=0 disabled=no
interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server lease
add address=192.168.101.11 comment="" disabled=no mac-address=
00:60:B0:CC:8B:D6 use-src-mac=yes
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 primary-dns=61.9.134.49 secondary-dns=
61.9.133.193
/ip firewall address-list
add address=192.168.102.2 comment=Centurion disabled=no list=DFBlck
add address=192.168.101.26 comment="HP 2023" disabled=no list=DFBlck
add address=192.168.103.2 comment=Wii disabled=no list=DFBlck
add address=192.168.103.3 comment=XBox disabled=no list=DFBlck
add address=192.168.101.8 comment="DF_Studio Switch" disabled=no list=DFBlck
add address=192.168.103.5 comment=SonyTV disabled=no list=DFBlck
add address=192.168.103.6 comment=PS3 disabled=no list=DFBlck
add address=192.168.101.9 comment=XCube disabled=no list=DFBlck
add address=192.168.101.29 comment="Nokia E65" disabled=no list=DFBlck
add address=192.168.101.7 comment=Cmaster disabled=no list="Study PCs"
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=drop chain=forward comment="Invalid Connections" connection-state=
invalid disabled=yes
add action=drop chain=forward comment="Morningblk DF" disabled=yes
src-address-list=DFBlck time=0s-5h15m,mon,tue,wed,thu,fri,sat
add action=drop chain=forward comment="Morningblk Study" disabled=yes
src-address-list="Study PCs" time=0s-5h15m,mon,tue,wed,thu,fri
add action=drop chain=forward comment=NightBlk disabled=yes src-address-list=
DFBlck time=23h45m-1d,sun,mon,tue,wed,thu
add action=drop chain=forward comment="Drop Connection fr Bridge to VoIP"
disabled=yes in-interface=bridge1 out-interface=VL-104
add action=drop chain=forward comment="Drop Connection fr VoIP to Bridge"
disabled=yes in-interface=VL-104 out-interface=bridge1
add action=accept chain=forward comment="Established Connections"
connection-state=established disabled=yes
add action=accept chain=forward comment="Related connections"
connection-state=related disabled=yes
/ip firewall mangle
add action=mark-packet chain=prerouting comment="" disabled=no dscp=26
new-packet-mark=VoIP-SIP passthrough=yes
add action=mark-packet chain=prerouting comment="" disabled=no dscp=46
new-packet-mark=VoIP-RTP passthrough=yes
add action=masquerade chain=srcnat comment="" disabled=no out-interface=
ether1
add action=masquerade chain=srcnat comment="" disabled=yes src-address=
192.168.0.0/16
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set VL-101 discover=yes
set VL-103 discover=yes
set VL-104 discover=yes
set VL-102 discover=yes
set bridge1 discover=yes
set VL-105 discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
/ip service
set telnet address=0.0.0.0/0 disabled=yes port=23
set ftp address=0.0.0.0/0 disabled=yes port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=yes port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
set VL-101 queue=default
set VL-103 queue=default
set VL-104 queue=default
set VL-102 queue=default
set bridge1 queue=default
set VL-105 queue=default
/radius incoming
set accept=no port=3799
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=Australia/Melbourne
/system clock manual
set dst-delta=+01:00 dst-end="apr/04/2010 03:00:00" dst-start=
"oct/04/2009 02:00:00" time-zone=+10:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MktRB450G
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=128.105.39.11 secondary-ntp=
128.105.39.12
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=
yes interface=all memory-limit=10 memory-scroll=no only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
