Topology :
R1 (ether2) <> (ether1) R2 (ether2) <> (ether2) R3
--- R1 Config : ---
/interface vlan add interface=ether2 name=vlan1111 vlan-id=1111
/ip address add address=192.168.251.1/30 interface=vlan1111 network=192.168.251.0
--- R2 Config : ---
/interface bridge add name=bridge1
/interface bridge port add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether1 pvid=1111
/interface bridge port add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether2 pvid=69
/interface bridge vlan add bridge=bridge1 tagged=ether2 untagged=ether1 vlan-ids=1111
/interface bridge vlan add bridge=bridge1 tagged=ether2,bridge1 vlan-ids=69
/interface vlan add interface=bridge1 name=Management vlan-id=69
/ip address add address=192.168.252.2/28 interface=Management network=192.168.252.0
/ip route add gateway=192.168.252.1
--- R3 Config : ---
/interface bridge add frame-types=admit-only-vlan-tagged name=bridge1 protocol-mode=mstp pvid=69 vlan-filtering=yes
/interface vlan add interface=bridge1 name=vlan1111 vlan-id=1111
/interface bridge vlan add bridge=bridge1 tagged=bridge1,ether2 vlan-ids=1111
/ip address add address=192.168.251.2/30 interface=vlan1111 network=192.168.251.0
/ip address add address=192.168.252.1/28 interface=Management network=192.168.252.0
/ip firewall nat add action=src-nat chain=srcnat src-address=192.168.252.0/28 to-addresses=192.168.251.2
/ip route add gateway=192.168.251.1
Achieve :
R3 can ping to R1
Problem :
With this config everything works, i can ping from R3 to R1, but when i set vlan-filtering=yes in R2, ping from R3 to R1 fail immediately, why is it ?
