VLAN Setup
Hi all
I have a setup with a Procurve 2910al and RB1200
The procurve has a few vlans, the RB is connected to Port4 on the procurve, which has a Tagged VLAN 101, with ip 10.176.1.1/28
The mt is connected to the procurve on port 8, I have configured a VLAN 101 interface on port8 and assigned IP 10.176.1.14/28
Should this not be enough to get access ? I cannot Ping any of the IP's from any of the units, anyone got an idea ?
admin@MikroTik] > /ip address print
ADDRESS NETWORK INTERFACE
0 10.100.50.1/24 10.100.50.0 ether10_vlan50
1 192.168.10.4/24 192.168.10.0 ether1
2 X 10.110.145.2/24 10.110.145.0 ether10_vlan154
3 10.100.70.1/24 10.100.70.0 ether10_vlan70
4 10.176.1.14/28 10.176.1.0 ether8vlan101
[admin@MikroTik] > /ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.10.1 1
1 ADC 10.100.50.0/24 10.100.50.1 ether10_vlan50 0
2 ADC 10.100.70.0/24 10.100.70.1 ether10_vlan70 0
3 ADC 192.168.10.0/24 192.168.10.4 ether1 0
4 ADC 10.176.1.0/28 10.176.1.14 ether8vlan101 0
[admin@MikroTik] >
Please excuse my limited visio skills :slight_smile:
Can you post /export compact ?
[admin@MikroTik] > /export compact
sep/18/2012 19:23:23 by RouterOS 5.20
software id = SIQR-JA9V
set 0 speed=1Gbps
/interface vlan
add interface=ether10 l2mtu=1596 name=ether10_vlan50 vlan-id=50
add disabled=yes interface=ether10 name=ether10_vlan154 vlan-id=154
add interface=ether10 l2mtu=1596 name=ether10_vlan70 vlan-id=70
add interface=ether8 l2mtu=1596 name=ether8vlan101 vlan-id=101
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp_pool1 ranges=10.100.70.50-10.100.70.254
add address-pool=dhcp_pool1 disabled=no interface=ether10_vlan70 name=dhcp1
relay=10.100.70.1
/queue simple
add limit-at=8M/8M max-limit=8M/8M name=VLAN_210_8Mbit
add address=10.100.50.1/24 interface=ether10_vlan50
add address=192.168.10.4/24 interface=ether1
add address=10.110.145.2/24 disabled=yes interface=ether10_vlan154
add address=10.100.70.1/24 interface=ether10_vlan70
add address=10.176.1.14/28 interface=ether8vlan101
/ip dhcp-relay
add dhcp-server=192.168.10.10 disabled=no interface=ether10_vlan50 name=
relay_vlan50
add dhcp-server=192.168.10.10 interface=ether10_vlan154 name=relay_vlan154
add address=10.100.70.0/24 gateway=10.100.70.1
set max-udp-packet-size=512 servers=192.168.10.9,192.168.10.10
/ip firewall address-list
add address=192.168.10.0 list=company-lan
add chain=forward protocol=icmp
add action=reject chain=forward protocol=icmp reject-with=icmp-admin-prohibited
/ip neighbor discovery
set ether10_vlan50 disabled=yes
set ether10_vlan70 disabled=yes
set ether8vlan101 disabled=yes
add distance=1 gateway=192.168.10.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
/queue interface
set ether10 queue=ethernet-default
set ether9 queue=ethernet-default
set ether7 queue=ethernet-default
set ether8 queue=ethernet-default
set ether6 queue=ethernet-default
set ether5 queue=ethernet-default
set ether4 queue=ethernet-default
set ether3 queue=ethernet-default
set ether2 queue=ethernet-default
set ether1 queue=ethernet-default
/system ntp client
set enabled=yes mode=unicast primary-ntp=192.168.10.10
[admin@MikroTik] >
Are you trying to ping from the router to the switch or from your computer connected to the router?
From the router to the switch, via the ether8vlan interface
Any one got a clue to why I cannot reach my VLAN’s between MT and HP ?
Morten
You need to set the state of the port to secure and add-if-missing in vlan-header.
So if it’s port 4 then this should probably be the setup:
set 3 vlan-header=add-if-missing vlan-mode=secure
This is taken from RB750G, I guess it’s similar in your case.
Thank you, well it is kind of similar, I am running a rb1200 and would like to use the ports that are not part of the internal switch for VLAN routing. I cannot find these settings on the ports.
Some other settings I need to complete on these ports maybe ?
Did you try the config line I provided? There might be two other lines you need to add, will take a look when I open my computer, I don’t have it in my head. :wink:
Did you solve this?
No not at all, still struggeling with this part.
Resolved? I have some similar problem…
