Vlan splitting
I'm trying to do a simple trunk -> access port vlan split per RouterOS - RouterOS - MikroTik Documentation (really, combining examples 1 and 3); when I have vlan filtering off, the vlan ip addresses are pingable over the tagged uplink port, but not when vlan filtering is turned off. Initially, a client on one of the access ports could ping the router, but that seems to have stopped working (the router is not responding to arp requests, nor sending them out).
feb/02/1970 20:32:01 by RouterOS 6.46.7
software id = G0ZP-8CHD
model = RB760iGS
serial number = A51A0980D52F
add name=uplink-bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment="handoff 1" speed=100Mbps
set [ find default-name=ether2 ] comment="handoff 2" speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] comment="Local access port" speed=100Mbps
set [ find default-name=sfp1 ] comment=uplink
/interface vlan
add interface=uplink-bridge name=vlan200 vlan-id=200
add interface=uplink-bridge name=vlan613 vlan-id=613
add bridge=uplink-bridge interface=ether1 pvid=200
add bridge=uplink-bridge interface=ether2 pvid=613
add bridge=uplink-bridge interface=sfp1
/interface bridge vlan
add bridge=uplink-bridge tagged=sfp1 untagged=ether1 vlan-ids=200
add bridge=uplink-bridge tagged=sfp1 untagged=ether2 vlan-ids=613
add address=192.168.88.1/24 comment=defconf interface=ether5 network=192.168.88.0
add address=207.55.110.1/30 interface=vlan200 network=207.55.110.0
add address=10.99.200.10/24 interface=vlan200 network=10.99.200.0
add address=10.99.113.10/24 interface=vlan613 network=10.99.113.0
Its not the complete config next time please include it all
(1) You forgot to tag also the bridge for both rules.
FM
TO
add bridge=uplink-bridge tagged=uplink-bridge,sfp1 untagged=ether1 vlan-ids=200
add bridge=uplink-bridge tagged=uplink-bridge,sfp1 untagged=ether2 vlan-ids=613
(2) A vlan network can only have one address what is the purpose of the line in red???
As for this vlan split you mention.
Please explain it more clearly.
There are three types of ports typically
a. Trunk port which is all tagged vlans 1 or more, that are going to a smart device that can read vlan tags
b. Access port which is one untagged vlan that is going to a dumb device that cannot read vlan tags.
c. hybrid port, less common, where one untagged vlan and 1 or more tagged vlans are going to a device that can handle both.
(ex. voip phone with two ports in the phone, the incoming data over tagged vlans is read by the phone, the untagged vlan goes out the second voip port to the associated PC - dumb device)
Doh! Thanks!
The 207 address is the real address of the vlan when it goes into production, I’m just testing with the 10.99 addresses
