Hello everyone
I have bought a Mikrotik CRS310 in my existing Ubiquiti network to use the 2.5Gbe interfaces to speed up my HomeLab.
Unfortunately I encountered some problems. I am not able to transfer the VLans correctly from Ubiquiti to Mikrotik. The server in VLan 20 is not pingable. The clients in VLan6 have no internet.
I have read various Youtube videos and also here in the forum and tried things out but I seem to have missed a point.
Here is the schematic and the config thanks already for Help.
The configuration you posted Is a partial one.
Particularly when there are connections issues it is needed a full configuration (edit it to mask sensitive data, serial, etc.) as the cause of the issue may be in an area that is (only seemingly) unrelated to the one(s) where you suspect being the problem and that you posted.
Dont use vlan1 for data on Mikrotik devices. Assuming vlan1 on the unifi…is the trusted vlan.
How is vlan1 data getting to the mikrotik, assuming untagged as unifi doesnt normally tag the management vlan.
If so you could consder ETH1 being a hybrid port into the MT.
Thank you very much for your contributions.
I have tested the configuration again. Created VLAN11 in Unfi and connected it to the port of the Microtik switch.
With US8 the devices work in VLAN 6
With the Mikrotik on E3, the Vlan 20 device cannot be reached with ping.
The Microtik management (Winbox) does not see the switch. The two Unfis switches US8 are also technically unreachable.
Well if you can tag the management subnet traffic on the unifi to vlan11 then thats a different outcome right.
Also, only vlan needing definition is the vlan11 ( the management vlan )
