VLAN support
HI,
I have an AP with 4 SSIDs
I would like to set different hotspot profiles to each SSIDs
What should I configure at the mikrotik when I have connected ethernet cable from the AP to ether 2 of mikrotik.
ether 1 is connected to WAN for internet connection.
I’ve configured 4 VLANS : VLAN 10,20,30,40 at ether 2 ports, and added corresponding profiles to each VLANs,
it does not work after it sees the hotspot page…do I need to do bridging for each VLAN? Pls assist anyone :slight_smile:
Add a Hotspot to each VLAN interface on the router. That’s it.
I’m assuming you created VLAN interfaces on the router.
