Hi im trying to segregate my home network in different vlans
i am using a 2011UAS-2HnD and i want to use the in switch chip tagging but it looks like packet are not tagged ingress
my router does not have the latest Os but if necessary i will upgrade ( probably gona try with an upgrade regardless)
what i am ultimatly trying to acheive is have a esxi trunked to the router and segregate my other devices.
unfortunatlly i am not even able to do the simplest of setup : 2 computers in the same vlan with static ip on both sides
no layer3 in router … just vlan segragation here. looks like ports are not tagging packet ingress… when i put checked or secure switch connection drops there . looks like i am missing some info here.
this is my info :
(dont mind comments on the eth interface)
PC#1 => eth9 (switch-vlan10) eth8 => PC#2
eth7,8,9 slave to eth6
THE DEVICE
[admin@Linksys] > /system license print
software-id: DA59-4R88
upgradable-to: v7.x
nlevel: 5
features:
[admin@Linksys] > /system routerboard print
routerboard: yes
model: 2011UAS-2HnD
serial-number: 4027023BF3A1
current-firmware: 3.0
upgrade-firmware: 3.04
[admin@Linksys] >
[admin@Linksys] > /system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 system 5.24
1 advanced-tools 5.24
2 routerboard 5.24
3 ppp 5.24
4 lcd 5.24
5 mpls 5.24
6 dhcp 5.24
7 calea 5.24
8 ipv6 5.24
9 multicast 5.24
10 hotspot 5.24
11 ntp 5.24
12 gps 5.24
13 wireless 5.24
14 ups 5.24
15 security 5.24
16 user-manager 5.24
17 routing 5.24
[admin@Linksys] >
THE CONFIG
[admin@Linksys] > interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 ;;; sfp cage
sfp1 1500 D4:CA:6D:7B:C3:BC enabled none switch1
1 R ;;; internet
wan 1500 D4:CA:6D:7B:C3:BD enabled none switch1
2 RS ;;; bond0
eth2 1500 D4:CA:6D:7B:C3:BE enabled none switch1
3 S eth3 1500 D4:CA:6D:7B:C3:BF enabled none switch1
4 ;;; lan
eth4 1500 D4:CA:6D:7B:C3:C0 enabled none switch1
5 R eth5 1500 D4:CA:6D:7B:C3:C1 enabled none switch1
6 ;;; media
eth6 1500 D4:CA:6D:7B:C3:C2 enabled none switch2
7 S eth7 1500 D4:CA:6D:7B:C3:C3 enabled eth6 switch2
8 S eth8 1500 D4:CA:6D:7B:C3:C4 enabled eth6 switch2
9 S eth9 1500 D4:CA:6D:7B:C3:C5 enabled eth6 switch2
10 ;;; dmz
eth10 1500 D4:CA:6D:7B:C3:C6 enabled none switch2
[admin@Linksys] >
[admin@Linksys] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 wlan1 br-lan 0x80 10 none
1 bond0 br-lan 0x80 10 none
2 I eth4 br-lan 0x80 10 none
3 eth5 br-lan 0x80 10 none
4 I eth10 br-dmz 0x80 10 none
[admin@Linksys] >
[admin@Linksys] > /interface ethernet switch print
Flags: I - invalid
# NAME TYPE MIRROR-SOURCE MIRROR-TARGET SWITCH-ALL-PORTS
0 switch1 Atheros-8327 none none
1 switch2 Atheros-8227 none none
[admin@Linksys] >
[admin@Linksys] > /interface ethernet switch vlan print
# SWITCH VLAN-ID PORTS
0 switch2 10 eth6
eth8
eth9
switch2_cpu
[admin@Linksys] >
[admin@Linksys] > /interface vlan print
# NAME MTU ARP VLAN-ID INTERFACE
0 vlan10 1500 enabled 10 eth6
[admin@Linksys] >
[admin@Linksys] > /interface ethernet switch port print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER
0 sfp1 switch1 disabled leave-as-is
1 wan switch1 disabled leave-as-is
2 eth2 switch1 disabled leave-as-is
3 eth3 switch1 disabled leave-as-is
4 eth4 switch1 disabled leave-as-is
5 eth5 switch1 disabled leave-as-is
6 eth6 switch2 secure add-if-missing
7 eth7 switch2 disabled leave-as-is
8 eth8 switch2 fallback always-strip
9 eth9 switch2 fallback always-strip
10 eth10 switch2 disabled leave-as-is
11 switch1_cpu switch1 disabled leave-as-is
12 switch2_cpu switch2 secure add-if-missing
[admin@Linksys] >
** note: regardless of #6 and 12 if #8,9 fallback/disabled == works if anything else does not
THE end
