VLAN to LAN Communication on a Wireless Network
Using the rb750gr3. I have an Access Point on eth3 set up with 4 SSIDs and each one pointing to a different VLAN. The eth2 interface has the 4 VLANs assigned to it with the eth3, eth4, and eth5 as slaves (default). My first VLAN is supposed to be connected to the internal LAN of the rb750 (gateway is assigned to eth2, DHCP removed, static only) and then the other 3 VLANs are isolated networks with gateways and DHCP servers assigned to the VLANs, rather than the interface. All three of the other VLANs work, but I can’t get any traffic across my main VLAN/SSID to the internal LAN. Any idea what might be causing this? I’ve tried creating a bridge and assigning both the VLAN and the eth2 interface to it but I still couldn’t get traffic across from the wireless SSID to a node plugged into eth2.
It works if I don’t tag the SSID as a VLAN. Any idea why?
