VLAN traffic between bridges
Hi, I have an RB1100AHx4 with the lastest 6.47 firmware installed. Currently it is running with three bridges for different LANS. The primary LAN has an upstream internet router, the second is bridging ports on a different LAN, the third is currently bridging VLAN traffic. It works well and I have no complaints.
The VLAN bridge has two tags, 0 and 1. I want to change the configuration so that they all see VLAN 1, but VLAN 0 traffic from one of the ports on the bridge needs to be connected to the primary LAN as untagged, and vice versa.
It appears that I cannot setup a bridge between bridges, and if I set up a new bridge I cannot have the port in two different bridges at the same time. How do I accomplish this? Suggestions are welcomed.
Try it using different numbers than 0 and 1, as i have read in the past that these may cause issues.
