Hi all,
I am a very beginner to Microtik and have been struggling for days on a very basic thing. Thing is I need to setup the following scenario :
I have the followinf configuration, i managed to create the bonding, and only one trunk to the layer 2 switch :
add admin-mac=D4:CA:6D:D3:17:34 auto-mac=no l2mtu=1598 name=bridge-local protocol-mode=rstp
set 0 name=ether1-CANL-RF
set 1 name=ether2-DSP-6500
set 2 name=ether3-DSP-6500
set 3 name=ether4-DSP-NOC
set 4 name=ether5-admin-SMC
set 5 name=ether6-DSP-RDC
set 6 master-port=ether6-DSP-RDC name=ether7-slave-local
set 7 name=ether8-slave-local
set 8 master-port=ether6-DSP-RDC name=ether9-slave-local
set 9 disabled=yes master-port=ether6-DSP-RDC name=ether10-DSP-ADM-RES
set 10 name=sfp1-gateway
/interface vlan
add interface=ether4-DSP-NOC l2mtu=1594 name=DSP-BUREAU vlan-id=115
add interface=ether4-DSP-NOC l2mtu=1594 name=DSP-INGE vlan-id=116
/interface bonding
add link-monitoring=none mode=802.3ad name="vers DSP-6500" slaves=ether2-DSP-6500,ether3-DSP-6500
I cannot add the vlan to other interfaces (i am actually using the Microtik Winbox tool).
I guess what i am doing wrong is the fact that a assigned the VLAN to a physical interface. I am not familiar at all with the bridges concepts and not sure at all if this is the right direction.
If anybody has an idea I would really appreciate your help !
Thanks a lot
Florian
