VLAN trunk over EoIP
Hi, I’m doing some work on a couple of 750G’s(ROS v5.5) and would like to trunk vlan’s over EoIP and would like someone to outline the basic steps to do this.
Basically I’d like to use eth5 on both units as the trunk, and use eth1,eth2,eth3,eth4 , as vlan1,2,3,4, in so that what goes in one port comes out on the other unit.
Is it possible to add a 3rd 750G, to this by putting in a switch on the original trunk and adding a second tunnel from say router 1?
After I get this done, I am considering adding IPSEC for the EoIP tunnel(s)( that might wait for another thread !). But if someone could outline the steps I need to acheive the trunk part, I’d be grateful.
Cheers.
Any particular reason you would want to crate Vlan through EOIP? Also, the easy way to get data going in on one port to come out on the other port is to bridge it. Maybe you could try and explain what you wish to do?
