VLAN Trunk over two RB250GS?
Hi there. Ive made the setup above successfully, but couldn’t figure how to connect a second RB250GS on the same way. As you can see above, SwOS port 1 have VLAN enabled with “add if missing” parameter selected. The other ports just have a pertinent VLAN ID and mode “strict” with “always strip”. All that works fine.
Please, help me on the scenario below. What is the SwOS config for port 5 on that first RB250GS and port 1 on that second one?
Ive made a couple tries with no success at all, is that even possible?
Thank you in advance.
Ozelo
Yes, this scenario should work without any problems. On 1st switch make sure you have entries in VLAN table with ether1,ether5 for each VLAN-ID and port5 set VLAN header = leave as is. There are no need for adjustments on 2nd switch.
Works like a charm! Thank you very much.
Ozelo
