i would like to add a 802.1q trunk port directly into a KVM guest, but i cannot make it work.
I created a bridge which contains the interface which is connected to a trunk port on my switch and the tap interface which is added to the KVM guest.
Is this scenario even possible?
Update:
Ok, my bad. I was tried to use a vlan in the KVM guest which was already defined and used on the host. Looks like it doesn’t work that way.
Thanks!
W.
