That is what i thought at first, but i don’t seem to setup it like i want.
it looks like it is for tagged only?
or do i need to setup the rules?
I need tagged vlan traffic on 1 interface and untagged on the other interfaces.
I have been able to make it work like this:
-Make a bridge per vlan,
-Assign ports to the bridge to which i wanted to have untagged traffic.
-Create vlans, assigned to the port where i want the tagged traffic over (for some reason ,I do not know, I need to enable the service tag, else it doesn’t work), (also in my case i needed to have the vlan’s an mtu of 1496 to work over powerline adaptors)
-on the bridge add the vlan’s device to the right bridge (to have the untagged traffic)
While doing some tests (making it work)
i think i stumbled upon a bug (which made testing harder)
When i tried to make a bridge, just for the vlan, assigned the tagged port, and made a vlan interface on that bridge.
Then removed the bridged from the interface list (not from the bridge menu) the vlan traffic kept going over the bridge interface.
I needed to remove the bridge from the bridge menu.
Also when i removed a vlan via the interfacelist, it removed the vlan from the vlan list, but not from the bridge ports, there it remained named as ‘unknown’
I think this are minor bugs, but they slowed my testing way down, cause i could send vlan traffic over my trunk, but i didn’t seem to get any traffic back, until i saw in bridge menu, the vlan bridge i made before had the traffic, but wasn’t assigned.
I know this wasn’t the way to work, but i was trying to make it work with the little documentation i found about this subject.
I hope i made this clear enough to reproduce, else i’ll try to put together the commandline commands to reproduce.
HW is Routerboard 560G, using 5.0rc4 software
Not to bash on your guys great work, but i don’t really understand why i need to make bridge interfaces
While on other brands, i just need to create vlan’s, assign them to and interface, define if it is tagged or not and that’s it.
I even can combine on them, so when there is untagged traffic on the interface, automaticly assigned to a vlan i defined as untagged traffic.
for example
on ether1 i can have tagged traffic of vlan 10 and 20, and the untagged traffic is for vlan 50 (for example)
in this case i this i caught this with the “interface ethernet switch”, i added a rule that defined, if there is no vlan header, add one with a certain tag.
(my last posts i was pretty tired, so that was why i was so brief)
