VLAN Trunk
My ISP is doing VLAN trunk to 1 link. (4 vlan id)
1st vlan is for internet
2nd vlan is for iptv
3rd vlan is for ipphone
4th vlan is for management
they provide a router on signup and i plan to assign 2nd, 3rd, 4th vlan to the router.
how can I do it.?
I manage to assign the 1st VLAN as dhcp client and is able to get a WAN IP from the ISP DHCP server and able to access to net.
I use bridge to bridge 2nd, 3rd, 4th vlan with port 3 on RB1100AH
the 2nd router(the one provided by ISP) WAN port is connected to port 3 of RB1100AH.
but on the ISP router, I am unable to grab an IP from the 2nd, 3rd, 4th vlan.
I am using cisco SLM2008 before this doing the same setup and its working.
but. do you put all vlan in same bridge? then you put the vlan together. you need one bridge per vlan, and one vlan per interface want it to be tagged to. If you want it untagged, bridge vland and the port. Not the vlan on the port itself.
2nd, 3rd, 4th vlan should be tagged on port 3 going to the router.
is something like http://blog.bravi.org/?p=319
but I am forwarding vlan trunk(4 vlan) from port 1 to port 3 (3 vlan)
From my point of view, you just need to create one bridge “br-trunk”, add the two ethernet interfaces to it and your ISP router should work. To catch a vlan at your router, just add a vlan on top of the bridge.
I am able to catch the first vlan on rb1100ah
I also bridge the wan port with the ether 3 connected to the other router from isp. But it is unable to get ip from those vlans
From what I read it seem like the vlan has been un tagged before being forward out on the other lan port.
