I have a HAP AC Lite that I would like to have 2 VLAN trunks with VLAN IDs 10,20,30,40 on ether1 and ether2. I would also like to have an access port for VLAN 20 on ether3 and an access port for VLAN30 on ether5.
I tried to do this without bridges but it didn’t seem to work. Most of the info on the forum seems to suggest that bridges are are required for this setup, but then I’m using the CPU right? Can this not all be accomplished in the switch chip?
I have a CRS125-24G-1S-RM on one of the trunks and a Zyxel POE switch on the other to power an IP camera.
That’s exactly what I was looking for. It seems like that would be good info to have in the VLAN section on the wiki.
I got the VLAN config onto the hap ac lite and at least one of the trunks seams to be working but the first access port I’ve tried doesn’t work. I had very limited time to work on it. I need to try a few more things. I will post back if I have trouble.
I’ve got the ethernet ports working the way I’d like, but now I’m trying to add the 2Ghz interface to vlan 10 but so far nothing I’ve changed seems to work. When I connect, my phone just says obtaining IP address and then fails. I’m not exactly sure what vlan-mode should be set to, but “no tag” and “use tag” don’t seem to make a difference. “use service tag” didn’t seem right seem right from what I found on the forum and the wiki.
I did change VLANs on ports 3 and 5 since my original post.
If you set vlan id for wlan, it works as untagged acccess port. Outgoing traffic is untagged and incoming is assigned to selected vlan. But if you want it to do anything useful, you need to connect it to something else, because currently the vlan is only on wlan and isolated from everything else. You could bridge wlan with ethernet (with vlan trunk) and it would connect vlan 10 on those interfaces.
But I’m not sure how it would play together with vlans set up on hardware switch, I don’t have much experience with that.
