I’ve reduced my configuration to a standalone MGMT on ether1, one trunked port, and one access port.
What I observe is that traffic coming from the access port gets switched to the trunked port, but has 2 802.1Q headers. The outer one has ID=0, the inner one has the expected VLAN tag. I observed this with packet capture on the device at the other end of the trunked port, and verified the traffic is going in untagged on the access port with pcap there. I have the configuration shown below, then run “/interface bridge set bridge vlan-filtering=yes”, observe the /interface bridge vlan table (looks as expected) but nothing works because of the VLAN ID=0 double tagging.
# BRIDGE VLAN-IDS CURRENT-TAGGED CURRENT-UNTAGGED
0 bridge1 10 bridge1 sfp-sfpplus4
sfp-sfpplus1
1 D bridge1 1 bridge1
sfp-sfpplus1
I tried a few things semi-random (turning off hardware on the bridge ports, downgrading to the long-term firmware version, changing ether-type to non-default). I found a few issues in forums around getting a stray VLAN ID=0 tag suggests the switch at egress considers the traffic untagged (so adds another one). At this point I am stumped, so if anyone has pointers, would appreciate it.
I considered just using SwOS since my use case is so simple. I have to admit I was a bit discouraged by
*) CRS305: fixed traffic forwarding between SFP+ ports;
[1] http://forum.mikrotik.com/t/swos-version-2-13-released/148753/1
add admin-mac=08:55:31:D3:64:CE auto-mac=no name=bridge1
add name=dhcpPoolMGMT ranges=192.168.99.2-192.168.99.254
add address-pool=dhcpPoolMGMT disabled=no interface=ether1 name=dhcpMGMT
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfp-sfpplus4 pvid=10
set discover-interface-list=none
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1 untagged=sfp-sfpplus4 vlan-ids=10
add address=192.168.99.1/24 interface=ether1 network=192.168.99.0
/ip cloud
set update-time=no
/ip dhcp-client
add disabled=no interface=bridge1
add address=192.168.99.0/24 dns-none=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/New_York
/system routerboard settings
set boot-os=router-os
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
