vlan unreachabel
A customer has three wAP ac setup for capsman using vlan (old version - ros 6.39). Two of them works fine. The third one does not communicate on ether1. The config is pretty much identical. Hostname and IP are the major differences as I can see.
Why does one of these not communicate on ether1?
I know it’s not a switch/cable issues because when the two units swap location, the problem follows the box.
When the box is reset and connected to a switch port without vlan, it works, so I’m sure this is a config issue - probably vlan-related. Can anyone see where the problem is?
(I’m trying to establish communication on vlan 201, between 192.168.201.13 (missconfigured wAP ac as CAP) and 192.168.201.10 (hAP ac acting as CAPsMAN. The working wAP ac’s has ip 192.168.201.11 and 192.168.201.12).
Edit:
Never mind. I forgot to add ether1 interface to bridge. Vlan on bridge sure won’t affect ports excluded from bridge
