Hi everyone,
I have been using the bridge vlan method for a while configuring mikrotik switches, but i have a doubt with the Frame Types.
As you can see on Bridge>Ports>VLAN>Frame-Types there is 3 options you can play with:
- Admit all (as it says, admits all the traffic).
- Admit only VLAN tagged. (It doesnt allow packages without vlan tags to pass through)
- Admit only untagged and priority tagged. (admit only packages without vlan tags AND priority tagged)
My doubt is only on the third option where it says “and priority tagged”, what does that means? if it admits untagged packets and tagged ones it is not the same as “admit all” option? i dont get the difference, i dont get what priority tagged means or where i can set it in case it is a hybrid port.
Can someone explain me? thanks!
