vlan with dynamic interfaces
When using capsman with several ssid’s, each connected to a vlan, each will make a dynamic interface on the cap that is member of the bridge.
So caps have more than one port. I.e. the cAP ac has two ports. The port that goes to the network / capsman has to have all vlans tagged. How can I make one of the vlans untagged on the other port?
(In the /bridge vlan config I end up thinking I’d have to specify the dynamic interfaces, which doesn’t sound right to me)
(In case it matters, local forwarding is enabled in this config.)
