VLAN with internet Access
Hi, I´m new to this forum, but not really to Mikrotik-Routers. So far I was able to handle everything on my own, but now I have a problem on which I need some advice.
I read a lot about VLAN´s, how to set them up and to configure everything the way you want.
So I started to setting up a VLAN ID 30 on an eth-interface. I assigned a dhcp Server and address range and it worked like a charm.
All Clients get an IP and are able to ping each other and the gateway.
The only thing I don´t get to work is getting internet access on the VLAN.
I setup a scrNat masq rule for the VLAN Address and setup a forward firewall roll to those Addresses.
I even tried to put the VLAN into the WAN-Bridge, which the VLAN DHCP Server didn´t like with a message such as, SERVER cant be SLAVE…
Can you tell me what I am missing?
If you need to see my running config, I could publish it
follow this guide,
If you use the default firewall rules you should be connected to the internet.
if not post your config here
