I have a mikrotik with a config that takes 2 vlans off of a bridge and untags them onto a port using another bridge. My config is outlined below. I do rate-limiting by packet marking the ports of the bridges. My issue is if I check the “use ip firewall” in the bridge setting the router quits passing traffic over the vlan. If I disable this setting the vlan starts working. ( Its the last setting in the config)
I need to do rate-limiting on a port that is on a bridge and using this is the only way I know how but it seems to be blocking the vlan.
add l2mtu=1594 name=“Vlan - 18 - Bridge”
add l2mtu=1594 name=“Vlan - 29 - Bridge”
add l2mtu=1598 name=“WAN Bridge”
/interface vlan
add interface=“WAN Bridge” l2mtu=1594 name=vlan18 vlan-id=18
add interface=“WAN Bridge” l2mtu=1594 name=vlan29 vlan-id=29
add bridge=“WAN Bridge” interface=“1 - Backhaul”
add bridge=“WAN Bridge” interface=“4”
add bridge=“WAN Bridge” interface=“10”
add bridge=“Vlan - 18 - Bridge” interface=vlan18
add bridge=“Vlan - 18 - Bridge” interface=“5”
add bridge=“WAN Bridge” interface=“6”
add bridge=“Vlan - 29 - Bridge” interface=“7A”
add bridge=“Vlan - 29 - Bridge” interface=vlan29
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=yes use-ip-firewall-for-vlan=yes
