VLANS and ARP Problem
Hello!
I’ve found a problem in using vlans.
There is:
rb751g-2hnd OS 6.1
ethernet5 - server connected.
Server has few vlan interfaces, for example we will use VLAN60. Server has address 192.168.60.254/24 on this interface.
Routerboard configuration:
Ports:
[admin@home] /interface ethernet switch port> print
Flags: I - invalid
 #   NAME        SWITCH        VLAN-MODE VLAN-HEADER    DEFAULT-VLAN-ID
 0   ether1-bridge-WAN        switch1        disabled  leave-as-is               auto
 1   ether2-bridge-WAN        switch1        disabled  leave-as-is               auto
 2   ether3-switch1-master        switch1        disabled  leave-as-is               auto
 3   ether4-switch1-slave        switch1        disabled  leave-as-is               auto
 4   ether5-switch1-slave        switch1        disabled  leave-as-is               auto
 5   switch1_cpu        switch1        disabled  leave-as-is               auto
VLANS:
[admin@home] /interface ethernet switch vlan> print
 #   SWITCH        VLAN-ID PORTS
 0   switch1        10 ether3-switch1-master
 1   switch1        20 ether3-switch1-master
 2   switch1        30 ether3-switch1-master
 3   switch1        40 ether3-switch1-master
 4   switch1        50 ether3-switch1-master
 5   switch1        60 ether3-switch1-master
Interfaces:
[admin@home] /interface> print
 #     NAME                                TYPE         MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  RS ether1-bridge-WAN                   ether       1500  1598       4074 D4:CA:6D:29:45:E0
 1  RS ether2-bridge-WAN                   ether       1500  1598       4074 D4:CA:6D:29:45:E1
 2  RS ether3-switch1-master               ether       1500  1598       4074 D4:CA:6D:29:45:E2
 3  R  ether4-switch1-slave                ether       1500  1598       4074 D4:CA:6D:29:45:E3
 4  RS ether5-switch1-slave                ether       1500  1598       4074 D4:CA:6D:29:45:E4
 5   S wlan0-bridge-LAN                    wlan        1500  2290            D4:CA:6D:29:45:E5
 6  R  LAN                                 bridge      1500  1598            D4:CA:6D:29:45:E1
 7  R  WAN                                 bridge      1500  1598            D4:CA:6D:29:45:E0
 8  R  vlan10                              vlan        1496  1594            D4:CA:6D:29:45:E2
 9  R  vlan20                              vlan        1496  1594            D4:CA:6D:29:45:E2
10  R  vlan30                              vlan        1496  1594            D4:CA:6D:29:45:E2
11  R  vlan40                              vlan        1496  1594            D4:CA:6D:29:45:E2
12  R  vlan50                              vlan        1496  1594            D4:CA:6D:29:45:E2
13  R  vlan60                              vlan        1496  1594            D4:CA:6D:29:45:E2
Bridges:
[admin@home] /interface bridge port> print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE        BRIDGE        PRIORITY  PATH-COST    HORIZON
 0 I  wlan0-bridge-LAN        LAN        0x80         10       none
 1    ether3-switch1-master        LAN        0x80         10       none
 2    ether1-bridge-WAN        WAN        0x80         10       none
 3    ether2-bridge-WAN        WAN        0x80         10       none
IP-addresses:
[admin@home] /ip address> print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; Home
     192.168.88.1/24    192.168.88.0    LAN
 1   ;;; ISP
     x.x.x.x/24   x.x.x.0    WAN
 2   ;;; vlan60
     192.168.60.1/24    192.168.60.0    vlan60
 3   ;;; vlan10
     192.168.10.1/24    192.168.10.0    vlan10
 4   ;;; vlan20
     192.168.20.1/24    192.168.20.0    vlan20
 5   ;;; vlan30
     192.168.30.1/24    192.168.30.0    vlan30
 6   ;;; vlan40
     192.168.40.1/24    192.168.40.0    vlan40
 7   ;;; vlan50
     192.168.50.1/24    192.168.50.0    vlan50
Problem:
Periodically traffic is losing between server(other hardware the same and other Routerboard ports the same) and router. Traffic could accidentally return(and could not)
Problem fixes(temporary) by clearing of ARP-entry on the server.
Interval of problem appearing is absolutely random.
Problem is observed only inside VLANs. On same link untagged traffic works perfectly - i.e. 192.168.88.1 is pinging and 192.168.60.1 is not.
Problem example:
root@pve2:~# ping 192.168.60.1
PING 192.168.60.1 (192.168.60.1) 56(84) bytes of data.
64 bytes from 192.168.60.1: icmp_req=1 ttl=64 time=0.209 ms
64 bytes from 192.168.60.1: icmp_req=2 ttl=64 time=0.228 ms
64 bytes from 192.168.60.1: icmp_req=3 ttl=64 time=0.237 ms
64 bytes from 192.168.60.1: icmp_req=4 ttl=64 time=0.227 ms
64 bytes from 192.168.60.1: icmp_req=5 ttl=64 time=0.207 ms
64 bytes from 192.168.60.1: icmp_req=6 ttl=64 time=0.216 ms
64 bytes from 192.168.60.1: icmp_req=7 ttl=64 time=0.215 ms
64 bytes from 192.168.60.1: icmp_req=8 ttl=64 time=0.219 ms
64 bytes from 192.168.60.1: icmp_req=9 ttl=64 time=0.223 ms
64 bytes from 192.168.60.1: icmp_req=10 ttl=64 time=0.221 ms
64 bytes from 192.168.60.1: icmp_req=11 ttl=64 time=0.223 ms
64 bytes from 192.168.60.1: icmp_req=12 ttl=64 time=0.228 ms
64 bytes from 192.168.60.1: icmp_req=13 ttl=64 time=0.226 ms
64 bytes from 192.168.60.1: icmp_req=14 ttl=64 time=0.232 ms
64 bytes from 192.168.60.1: icmp_req=15 ttl=64 time=0.239 ms
64 bytes from 192.168.60.1: icmp_req=16 ttl=64 time=0.227 ms
64 bytes from 192.168.60.1: icmp_req=17 ttl=64 time=0.212 ms
64 bytes from 192.168.60.1: icmp_req=18 ttl=64 time=0.188 ms
64 bytes from 192.168.60.1: icmp_req=19 ttl=64 time=0.216 ms
64 bytes from 192.168.60.1: icmp_req=20 ttl=64 time=0.210 ms
64 bytes from 192.168.60.1: icmp_req=21 ttl=64 time=0.218 ms
64 bytes from 192.168.60.1: icmp_req=22 ttl=64 time=0.209 ms
64 bytes from 192.168.60.1: icmp_req=23 ttl=64 time=0.212 ms
64 bytes from 192.168.60.1: icmp_req=24 ttl=64 time=0.209 ms
^C
--- 192.168.60.1 ping statistics ---
36 packets transmitted, 24 received, 33% packet loss, time 34999ms
rtt min/avg/max/mdev = 0.188/0.218/0.239/0.021 ms
root@pve2:~# arp -d 192.168.60.1
64 bytes from 192.168.60.1: icmp_req=1 ttl=64 time=0.921 ms
64 bytes from 192.168.60.1: icmp_req=2 ttl=64 time=0.232 ms
64 bytes from 192.168.60.1: icmp_req=3 ttl=64 time=0.222 ms
^C
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.222/0.458/0.921/0.327 ms
Question: What am I doing wrong?
Thank you in advance!
Hello!
Problem was resolverd - there was Proxy ARP on the server :frowning:
