Hi.
I have RB1200 and I want to use 1Gb/s switch to maximize throughoutput.
I have HP Proliant Server with NIC1 and NIC2.
I have Netgear NAS with NIC1 and NIC2.
I plan to create VLANS:
VLAN 2 - storage - HP Proliant server NIC2 + Netgear NAS NIC2 (ethernet4 + ethernet5)
VLAN 3 - internet ethernet10 (may be I will add some ports to VLAN3 later…)
VLAN 4 - LAN storage - HP Proliant server NIC1 + Netgear NAS NIC1 (will add VLAN 5) (ethernet1 + ethernet2)
VLAN 5 - Management - HP Proliant server NIC1 (iLO. NIC1 = shared port) + Netgear NAS NIC1 (will add VLAN 5) (ethernet1 + ethernet2)
So… I hane ethernet1 and ethernet2 in the VLAN4 and VLAN5 at one time.
Ho to create “right” config?
Sorry. Forgot. MikroTik will be as firewall and router between management, storage and LAN networks…
Try to use this link: http://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#Vlan_Table
Try to make new config:
Port ether1 = tagged (VLAN4 - lan, VLAN5 - management) trunk
Port ether2 = untagged (VLAN5 -management) access
Config from mikrotik:
/interface ethernet switch port> print
# NAME SWITCH VLAN-MODE VLAN-HEADER
3 ether2 switch1 secure always-strip
4 ether1 switch1 secure add-if-missing
/interface ethernet switch rule> print
0 switch=switch1 ports=ether2 vlan-header=not-present copy-to-cpu=no redirect-to-cpu=no mirror=no new-dst-ports=ether1 new-vlan-id=4
1 switch=switch1 ports=ether1 vlan-header=present vlan-id=5 copy-to-cpu=no redirect-to-cpu=no mirror=no new-dst-ports=ether2
/interface ethernet switch vlan> print
# SWITCH VLAN-ID PORTS
0 switch1 4 ether1
1 switch1 5 ether1
2 switch1 0 ether2
But how to add IP-addresses to VLAN5 and VLAN4?
Port ether 4 + Port 5 = bridge - It’s easy…
Read this to understand how Mikrotik handles VLANs
http://blog.butchevans.com/2010/02/to-tag-or-not-to-tag-that-is-the-question/
Thank’s. It’s working. I tested with Nortel BayStack 450-24T. All working with this config:
- create (interface) vlan4 = ether1
- create (interface) vlan5 = ether1
- create bridge-vlan4 - I think, not needed
- create bridge-vlan5 = vlan4 + ether2 (untagged access)
- Add IP addresses to vlan4 and vlan5
on baystack I created trunk port 1 and connected with ether1 (Mikrotik), then I create access port 4 in vlan4 and access port 5 in vlan5. I try to ping from access port 5 devices at ether2 on mikrotik and it was working. Then I try to ping from access port 4 ip-address of vlan4 (mikrotik). Success again. Thank’s!
