VLANS HP1910 and RB750r3
Before I waste my life on google, can anyone tell me if it is possible to setup VLANs using the HP1910 and my RB. I am struggling to find anything on the net specific to my switches and the RB. The HP1910 is layer 2 with some basic layer 3 functions like static routing.
Any guidance would be appreciated.
Thanks.
Yes, you can.
Remember that VLAN is a Standar part of 802.1q, you can config the 1910 and MIKRORIK like any other switch.
Regards.
