Hi, I have a CCR1009-7G-1C-1S+ which does not have a switch chip. I have VLANs fully working on my installed router that was setup a year or two ago before all of the changes to bridges, etc. I have a second identical router that I thought I’d take advantage of and reprogram to replace my router. While my current config works with VLANs just fine I don’t know if its the best way. The config I’m posting below is untested and is from the new, yet to be installed router, its based on the current router and I’ve removed some of the irrelevant parts.
I have each VLAN on its own interface feeding various switches downstream (Cisco SG500 or Cisco SG300). Since each VLAN is on its own interface I don’t know if I need to create a bridge or do anything beyond what I’ve done. I’m looking for best performance, but also best safety/flexibility to allow isolation of VLANs (i.e. office VLAN can access others, nothing can access office, guest can’t access anything, etc.). I haven’t yet put any rules in this firewall to drop traffic between VLANs.
Sorry for no diagram but network overview is as follows:
Verizon ONT - to Ether 7 on tik (WAN)
Combo port on tik to Cisco SG500 (VLAN3)
Ether 1 on tik to Cisco SG500 (VLAN1 - this is untagged ports on Cisco also)
Ether 2 on tik to Cisco SG500 (VLAN2 - no DHCP, static only)
Ether 4 on tik to Cisco SG500 (VLAN4)
Ether 5 on tik to Cisco SG500 (VLAN5)
If I’ve provided enough info should I keep VLANs as is or should be using the bridge menu and the VLAN subsection of it?
Also, I’m testing the interface lists so not sure those are correct at this point.
# model = CCR1009-7G-1C-1S+
# serial number = XXXXXXXXXXXX
/interface vlan
add comment="Camera Traffic" interface=ether2 name=vlan2-Camera vlan-id=2
add comment="Secure Office Traffic" interface=combo1 name=vlan3-Office vlan-id=\
3
add comment="Trusted Local Traffic" interface=ether4 name=vlan4-TrustedLocal \
vlan-id=4
add comment="Guest Traffic" interface=ether5 name=vlan5-Guest vlan-id=5
add name=WAN
add exclude=WAN include=all name=LAN
/ip ipsec policy group
add name=ipsec+l2tp
add name=Automation ranges=10.0.1.101-10.0.1.199
add name=Guest ranges=10.0.5.100-10.0.5.150
add name=Office ranges=10.0.3.100-10.0.3.246
add name=VPN ranges=172.31.255.247-172.31.255.254
add name=TrustedLocal ranges=10.0.4.100-10.0.4.200
add address-pool=Automation disabled=no interface=ether1 lease-time=1d name=\
Automation
add address-pool=Guest disabled=no interface=vlan5-Guest lease-time=8h name=\
Guest
add address-pool=Office disabled=no interface=vlan3-Office lease-time=1d name=\
Office
add address-pool=TrustedLocal disabled=no interface=vlan4-TrustedLocal \
lease-time=1d name=TrustedLocal
/ppp profile
add change-tcp-mss=yes local-address=10.0.3.1 name="ipsec+L2TP VPN" \
remote-address=VPN use-encryption=yes
set discover-interface-list=!WAN
/interface l2tp-server server
set authentication=mschap2 default-profile="ipsec+L2TP VPN" enabled=yes \
use-ipsec=yes
add interface=ether7 list=WAN
add interface=ether1 list=LAN
add address=10.0.1.1/24 comment=Automation interface=ether1 network=10.0.1.0
add address=10.0.2.1/24 comment=Cameras interface=vlan2-Camera network=10.0.2.0
add address=10.0.3.1/24 comment=Office interface=vlan3-Office network=10.0.3.0
add address=10.0.4.1/24 comment="Trusted Local" interface=vlan4-TrustedLocal \
network=10.0.4.0
add address=10.0.5.1/24 comment=Guest interface=vlan5-Guest network=10.0.5.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether7
/ip dhcp-server lease
SECTION REMOVED
add address=10.0.1.0/24 dns-server=208.67.222.123,208.67.220.123 gateway=\
10.0.1.1
add address=10.0.2.0/24 dns-server=1.1.1.1 gateway=10.0.2.1
add address=10.0.3.0/24 dns-server=10.0.3.1 gateway=10.0.3.1
add address=10.0.4.0/24 dns-server=208.67.222.123,208.67.220.123 gateway=\
10.0.4.1
add address=10.0.5.0/24 dns-server=208.67.222.123,208.67.220.123 gateway=\
10.0.5.1
set allow-remote-requests=yes servers=1.1.1.1
/ip firewall address-list
add address=10.0.1.0/24 list=Automation
add address=10.0.5.0/24 list=Guest
add address=10.0.3.0/24 list=Office
add address=10.0.2.0/24 list=Cameras
add address=10.0.4.0/24 list=TrustedLocal
add address=172.31.255.0/24 list=VPN
established,related,untracked
add action=accept chain=input comment="VPN ipsec" protocol=ipsec-esp
add action=accept chain=input comment="VPN ipsec" dst-port=500,4500,1701 \
protocol=udp
add action=accept chain=input comment="Winbox over Internet" disabled=yes \
dst-port=8291 protocol=tcp
invalid
add action=drop chain=input comment="Drop Invalid DNS Connections" dst-port=53 \
in-interface-list=!LAN protocol=tcp
in-interface-list=!LAN protocol=udp
add action=drop chain=input comment="Drop Inbound SNMP" dst-port=161,162 \
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment="masquerade loopback" \
dst-address-list=LocalNet ipsec-policy=out,none out-interface-list=LAN \
src-address-list=LocalNet
add action=jump chain=dstnat comment="Pinhole Jump" dst-address=!10.0.0.0/16 \
dst-address-type=local jump-target=pinholes
NUMEROUS PINHOLES HERE
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=10.0.3.0/24,10.0.1.0/24 port=8291
set api-ssl disabled=yes
/ppp secret
add comment="ipsec+L2TP VPN" name=User1 profile="ipsec+L2TP VPN" service=\
l2tp
add comment="ipsec+L2TP VPN" name=User2 profile="ipsec+L2TP VPN" \
service=l2tp
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=“CCR1009”
/system ntp client
set enabled=yes
/system routerboard settings
set silent-boot=no
/system scheduler
add interval=12h name=UpdateNTP on-event=UpdateNTP policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-time=startup
/system script
add name=UpdateNTP owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\"{\
\r\
\n:local ntpServer \"pool.ntp.org\"\r\
\n:local primary [resolve \$ntpServer]\r\
\n:local secondary [resolve \$ntpServer]\r\
\n/system ntp client set primary-ntp \$primary\r\
\n/system ntp client set secondary-ntp \$secondary\r\
\n}\""
/tool mac-server
/tool mac-server mac-winbox
