So I am another victim of this ‘nice’ switch. All I want is very simple configuration for now, have two ports in single broadcast domain, one port working as untagged, another as tagged for the single vlan. For procurve, it took approx. 5 minutes to figure out the config, with RouterOS 6.13 I cannot make this work at all. Not to mention the so called documentation which restates the names of the config knobs without explaining the meaning.
So I did:
[kostik@MikroTik] > interface ethernet 23 set name=ether24
[kostik@MikroTik] > interface ethernet set 23 name=ether24 master-port=none
[kostik@MikroTik] > interface ethernet set 22 name=ether23 master-port=ether24
[kostik@MikroTik] > interface ethernet printFlags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1-master-local 1500 D4:CA:6D:F8:E8:83 enabled none switch1
1 S ether2-slave-local 1500 D4:CA:6D:F8:E8:84 enabled ether1-master-local switch1
2 S ether3-slave-local 1500 D4:CA:6D:F8:E8:85 enabled ether1-master-local switch1
3 RS ether4-slave-local 1500 D4:CA:6D:F8:E8:86 enabled ether1-master-local switch1
4 S ether5-slave-local 1500 D4:CA:6D:F8:E8:87 enabled ether1-master-local switch1
5 S ether6-slave-local 1500 D4:CA:6D:F8:E8:88 enabled ether1-master-local switch1
6 S ether7-slave-local 1500 D4:CA:6D:F8:E8:89 enabled ether1-master-local switch1
7 S ether8-slave-local 1500 D4:CA:6D:F8:E8:8A enabled ether1-master-local switch1
8 S ether9-slave-local 1500 D4:CA:6D:F8:E8:8B enabled ether1-master-local switch1
9 S ether10-slave-local 1500 D4:CA:6D:F8:E8:8C enabled ether1-master-local switch1
10 S ether11-slave-local 1500 D4:CA:6D:F8:E8:8D enabled ether1-master-local switch1
11 S ether12-slave-local 1500 D4:CA:6D:F8:E8:8E enabled ether1-master-local switch1
12 S ether13-slave-local 1500 D4:CA:6D:F8:E8:8F enabled ether1-master-local switch1
13 S ether14-slave-local 1500 D4:CA:6D:F8:E8:90 enabled ether1-master-local switch1
14 S ether15-slave-local 1500 D4:CA:6D:F8:E8:91 enabled ether1-master-local switch1
15 S ether16-slave-local 1500 D4:CA:6D:F8:E8:92 enabled ether1-master-local switch1
16 S ether17-slave-local 1500 D4:CA:6D:F8:E8:93 enabled ether1-master-local switch1
17 S ether18-slave-local 1500 D4:CA:6D:F8:E8:94 enabled ether1-master-local switch1
18 S ether19-slave-local 1500 D4:CA:6D:F8:E8:95 enabled ether1-master-local switch1
19 S ether20-slave-local 1500 D4:CA:6D:F8:E8:96 enabled ether1-master-local switch1
20 S ether21-slave-local 1500 D4:CA:6D:F8:E8:97 enabled ether1-master-local switch1
21 S ether22-slave-local 1500 D4:CA:6D:F8:E8:98 enabled ether1-master-local switch1
22 S ether23 1500 D4:CA:6D:F8:E8:99 enabled ether24 switch1
23 ether24 1500 D4:CA:6D:F8:E8:9A enabled none switch1
24 S sfp1-slave-local 1500 D4:CA:6D:F8:E8:9B enabled ether1-master-local switch1
[kostik@MikroTik] > interface ethernet switch ingress-vlan-translation add port=ether23 new-customer-vid=1 sa-learning=yes
[kostik@MikroTik] > interface ethernet switch egress-vlan-translation add port=ether24 customer-vid=1 new-customer-vid=0
[kostik@MikroTik] > interface ethernet switch ingress-vlan-translation print
0 ports=ether23 service-vlan-format=any customer-vlan-format=any new-customer-vid=1 pcp-propagation=no sa-learning=yes
1 D ports=ether23,ether24 service-vlan-format=any customer-vlan-format=any new-customer-vid=0 pcp-propagation=no sa-learning=yes
2 D ports="" service-vlan-format=any customer-vlan-format=any new-customer-vid=0 pcp-propagation=no sa-learning=no
[kostik@MikroTik] > interface ethernet switch egress-vlan-translation print
0 ports=ether24 service-vlan-format=any customer-vlan-format=any customer-vid=1 new-customer-vid=0 pcp-propagation=no
[kostik@MikroTik] > interface ethernet switch vlan print
# VLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 D 4095 switch1-cpu no no no no none
1 D 4091 ether23 no yes no no none
ether24
switch1-cpu
Now, if I do tcpdump on ws connected to the port ether24, I see untagged packets coming out:
pooma% sudo tcpdump -i em1 -n -vvv -e
192.168.102.80.63206 > 239.255.255.250.1900: [udp sum ok] UDP, length 395
13:11:53.399754 00:22:4d:7a:47:f6 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 496: (tos 0x0, ttl 2, id 21917, offset 0, flags [none], proto UDP (17), length 482)
192.168.102.80.63206 > 239.255.255.250.1900: [udp sum ok] UDP, length 454
13:11:53.399756 00:22:4d:7a:47:f6 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 437: (tos 0x0, ttl 2, id 21918, offset 0, flags [none], proto UDP (17), length 423)
Could, please, anybody help me. I want the untagged packets from port ether23 come out on port ether24 as tagged for vlan id 1, and tagged packets from port ether24 for vlan id 1 to come out to port ether 23, untagged. Would ether24 deny receive of any other tags or untagged packets, it would be good as well.
Thank you.
