Hi!
I have been using wireless bridges for many years for both small scale and full carrier applications.
I have to admit there are few things that confuse me about the W60G’s.
I want to use them as a PTP link between two switches which have VLANS on the trunk ports. I have basically 3 VLANS (100, 200, 300) and I want them for the following:
100: Management (of switches, the W60G etc)
200: IT VLAN
300: VOIP
I have a configured pair that passes data no worries, but the management of them is not tagged.
I want them to pass all VLANs transparently and for the management of the radios to be on VLAN ID 100.
Is there an easy way to tag the management or do all these VLANS need to be programmed into the W60Gs?
Many thanks!
