Hello
I’m trying to set up VLANs on mikrotik - without success
Basically my new ISP gave me INTERNET on VLAN 554 with PPPoE and on VLAN 555 there is IPTV
ISP told me that IPTV STB device will get DHCP address from ISP so there is no need for DHCP server for vlan 555
and I’ve asked ISP do I need to set up IGMP Proxy and answer was No
so far my test configuration looks like:
# Bridge
/interface/bridge/set [find name=bridge] name=bridge1
# VLAN
/interface vlan
add interface=bridge1 name=vlan554 vlan-id=554
add interface=bridge1 name=vlan555 vlan-id=555
add bridge=bridge1 interface=ether1 frame-types=admit-only-vlan-tagged ingress-filtering=yes
/interface/bridge/port/set [find interface=ether2] pvid=554 frame-types=admit-only-untagged-and-priority-tagged
/interface/bridge/port/set [find interface=ether3] pvid=554 frame-types=admit-only-untagged-and-priority-tagged
/interface/bridge/port/set [find interface=ether4] pvid=555 frame-types=admit-only-untagged-and-priority-tagged
/interface/bridge/port/set [find interface=ether5] pvid=555 frame-types=admit-only-untagged-and-priority-tagged
/interface bridge vlan
add bridge=bridge1 vlan-ids=554 tagged=bridge1,ether1 untagged=ether2,ether3
add bridge=bridge1 vlan-ids=555 tagged=bridge1,ether1 untagged=ether4,ether5
/ip dhcp-client/remove [find interface=ether1]
# PPPoE
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan554 name=pppoe-out1 password=passwd use-peer-dns=yes user=usr
add comment=defconf interface=pppoe-out1 list=WAN
# VLAN filtering
/interface/bridge/set [find name=bridge1] igmp-snooping=yes
/interface/bridge/set [find name=bridge1] vlan-filtering=yes ingress-filtering=yes
full config: (without vlan filtering on)
# 2025-03-10 12:15:18 by RouterOS 7.18.2
# model = E50UG
add admin-mac=CUT auto-mac=no comment=defconf igmp-snooping=yes name=bridge1
/interface vlan
add add-default-route=yes disabled=no interface=vlan554 name=pppoe-out1 use-peer-dns=yes user=usr
add comment=defconf name=WAN
add comment=defconf name=LAN
/disk settings
set auto-media-interface=bridge1 auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge1 comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=554
add bridge=bridge1 comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=554
add bridge=bridge1 comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=555
add bridge=bridge1 comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=555
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether1
add bridge=bridge1 tagged=bridge1,ether1 untagged=ether2,ether3 vlan-ids=554
add bridge=bridge1 tagged=bridge1,ether1 untagged=ether4,ether5 vlan-ids=555
add comment=defconf interface=bridge1 list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=192.168.88.0
add address-pool=default-dhcp interface=bridge1 name=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
after setting that configuration I’m disconnected from device and I’m not getting IP from mikrotik device so something is wrong
so it would be great if someone could help me
I’ve also got few questions:
- I just don’t know if interface vlan should be added to ether1 or to bridge1 ? In my example I’ve added it to bridge1 (suggestion from chatgpt)
- is turning on vlan filtering with default pvid 1 is fine because ofc we’ve got two incoming vlans?
- I was even experimenting with two bridges - one for internet and one for IPTV but I think its not recommended on Hex E50UG that I have? and I’ve got problem with adding ether1 to vlans because I can assign only it to one bridge
if config above will be working my plan is to check if I need to add
add action=accept chain=forward in-interface=vlan555 place-before=0
add action=accept chain=input in-interface=vlan555 place-before=0
add action=accept chain=output out-interface=vlan555 place-before=0
add action=accept chain=forward out-interface=vlan555 place-before=0
add interface=vlan555 list=WAN
something like that for IPTV
