I have configured VLANs on my CCR, then I have a 1st NetPower16p connected to a trunk port on the CCR and passing VLANS to the devices connected to it ports, no issues here everything working fine.
I wanted to pass the same VLANs to a remote site, to a 2nd NetPower16P, i connected the AirFiber Ap to a second trunk port on the first NetPower16p to the trunk port on the second NetPower16. All VLANs are passing fine everything working as expected.
CCR and both NetPowers have configured IPs in the management VLAN. we set the airfibers on the same network range but now we cannot reach them.
From a device on mamagement vlan we can reach router and netpowers, but not the radios.
You should be able to simply change the port on the tik to one radio to untagged management (access mode) and then access them as you have the right IP range.
Remember when you do it all the data thru the link will stop so make sure you do it from the end you are not relying on passing thru the radios
