ive tried to configure VLANs over bonding interfaces but so far without success.
Lets say if i have 2 VLANs, "VL_Pivate" and "VL_Pubic", and on router A i have bonding interface "bonding_to_B" and on router B i have bonding interface "bonding_to_A".
With this setup i cant get a connection from router A to B. If i remove the VLANs from the bridge and instead connect the bonding interfaces directly into the bridges it DOES WORK. I. e. i can ping the other side from both routers.
Anyone has an idea whats wrong? Cant i do VLANs over Bonding interfaces or do i have to choose a different approac?
I have the same problem. I want to build a bridge over one bonding-interface (802.3ad to CISCO SF300 with tagged VLANs) and one ethernet-port (tagged VLANs HP ProCurve) to have a L2 connection.
For L3 inter vlan routing, my VLANs have the bridge as interface.
But it does not work! Bonding slaves: Link goes up and down…
The same bonding-interface without the bridge with directly attachet VLANs and e.g. one different VLAN on the ethernet-port is working (only L3 connection).
But I want the same VLANs on the bonding-interface and ethernet-port (L2 and L3 connection)?
I use RB3011 with RouterOS 6.35rc42.
Hi marcol ,
i have the same situation - do you found a solution for this till now ?
I have seen this is older post but I have done this situation.
I have MT with 5 ethernet ports, 2ports of 5 are in Port-Chanel (bonding MT) mode and this is connection goes to Cisco sw L2 in port-channel mode too.
But I needed another two ports on Mikrotik router in VLAN 10 and Port-channel too but like Trunk port. I added VLAN 10 and 20 on bridge interface and automatically I have gotten trunk port on Bonding interface on MT device.
I set up native VLAN 10 and I got ip subne 10.10.10.0/24
