Can Vlans be transmited through a EOIP tunnel ?
Gino
Gino
Yes
GReat ! thanks, do I need to change the MTU of the EOIP tunnel to 1504 bytes ?
I am guessing that to carry VLANs over EOIP you will also have to add the appropriate VLAN interfaces to each end of the EOIP bridge.
If that guess is correct, you would leave the EOIP MTU at 1500.
Otherwise its like dot q over dot q via a dot q capable device. Usually that ends up breaking stuff…
