Hello, I recently configured a CRS125-24G-1S-RM switch to use vlans and switch chip. I created an script for that and would like some validation and comments. Here we have.
First, how network is segmented:
Servers => vlan 10 - 192.168.10.0/24 ports 1, 5, 6, 7 e 8
Clients => vlan 20 - 192.168.20.0/24 ports 1, 9, 10, 11 e 12
Clients => vlan 30 - 192.168.30.0/24 ports 1, 13, 14, 15 e 16
Clients => vlan 40 - 192.168.40.0/24 ports 1, 17, 18, 19 e 20
Clients => vlan 50 - 192.168.50.0/24 ports 1, 21, 22, 23 e 24
Management => vlan 100 - 192.168.100.0/24 ports 1, 2, 3, 4 e 5
/interface vlan
add name=vlan10 vlan-id=10 interface=ether1-master-local
add name=vlan20 vlan-id=20 interface=ether1-master-local
add name=vlan30 vlan-id=30 interface=ether1-master-local
add name=vlan40 vlan-id=40 interface=ether1-master-local
add name=vlan50 vlan-id=50 interface=ether1-master-local
add name=vlan100 vlan-id=100 interface=ether1-master-local
add address=192.168.10.254/24 interface=vlan10 network=192.168.10.0
add address=192.168.20.254/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.254/24 interface=vlan30 network=192.168.30.0
add address=192.168.40.254/24 interface=vlan40 network=192.168.40.0
add address=192.168.50.254/24 interface=vlan50 network=192.168.50.0
add address=192.168.100.254/24 interface=vlan100 network=192.168.100.0
add ports=ether5-slave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local,switch1-cpu vlan-id=10
add ports=ether9-slave-local,ether10-slave-local,ether11-slave-local,ether12-slave-local,switch1-cpu vlan-id=20
add ports=ether13-slave-local,ether14-slave-local,ether15-slave-local,ether16-slave-local,switch1-cpu vlan-id=30
add ports=ether17-slave-local,ether18-slave-local,ether19-slave-local,ether20-slave-local,switch1-cpu vlan-id=40
add ports=ether21-slave-local,ether22-slave-local,ether23-slave-local,ether24-slave-local,switch1-cpu vlan-id=50
add ports=ether2-slave-local,ether3-slave-local,ether4-slave-local,switch1-cpu vlan-id=100
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu vlan-id=10
add tagged-ports=switch1-cpu vlan-id=20
add tagged-ports=switch1-cpu vlan-id=30
add tagged-ports=switch1-cpu vlan-id=40
add tagged-ports=switch1-cpu vlan-id=50
add tagged-ports=switch1-cpu vlan-id=100
/interface ethernet switch ingress-vlan-translation
add ports=ether5-slave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local new-customer-vid=10
add ports=ether9-slave-local,ether10-slave-local,ether11-slave-local,ether12-slave-local new-customer-vid=20
add ports=ether13-slave-local,ether14-slave-local,ether15-slave-local,ether16-slave-local new-customer-vid=30
add ports=ether17-slave-local,ether18-slave-local,ether19-slave-local,ether20-slave-local new-customer-vid=40
add ports=ether21-slave-local,ether22-slave-local,ether23-slave-local,ether24-slave-local new-customer-vid=50
add ports=ether2-slave-local,ether3-slave-local,ether4-slave-local new-customer-vid=100
With this all vlans communicate among them.
Comments, any thoughts?
I appreciate,
Marcello.
