In 4.x does anyone yet know if mixed tagged and untagged inbound traffic on a single ethernet interface can be easily split/separated yet?
I’m still hoping for the day I can create a bunch of VLAN interfaces atop that single eth. interface to capture tagged traffic AND simultaneously apply a bridge directly to the ethernet and have it ONLY capture untagged traffic. Or perhaps have a VLAN work-around whereby a special VLAN interface (maybe use vlan-id=0 perhaps?) can be created that captures untagged traffic on an eth. port.
In 3.x (and I suspect it’s still true in 4.x), inbound mixed tagged/untagged traffic will ALL be captured by the bridge applied to the eth. interface, and the VLAN interfaces will see nothing. And if I recall correctly, attempting to layer VLAN interfaces atop a bridge didn’t work either.
Goal:
[admin@mikrotik] > /interface vlan print
Flags: X - disabled, R - running, S - slave
# NAME MTU ARP VLAN-ID INTERFACE
0 R eth1_untagged7 1500 enabled 0 ether1
1 R eth1_vlan8 1500 enabled 8 ether1
2 R eth1_vlan9 1500 enabled 9 ether1
3 R eth2_vlan7 1500 enabled 7 ether2
4 R eth2_vlan8 1500 enabled 8 ether2
5 R eth2_vlan9 1500 enabled 9 ether2
[admin@mikrotik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 eth1_untagged7 vlan7_bridge 0x80 10 none
1 eth1_vlan8 vlan8_bridge 0x80 10 none
2 eth1_vlan9 vlan9_bridge 0x80 10 none
3 eth2_vlan7 vlan7_bridge 0x80 10 none
4 eth2_vlan8 vlan8_bridge 0x80 10 none
5 eth2_vlan9 vlan9_bridge 0x80 10 none
6 ether3 vlan9_bridge 0x80 10 none
In the above example, ether1 would have mixed tagged/untagged traffic, ether2 only tagged traffic, and ether3 only untagged traffic. The above example assumes a new feature vlan-id=0 to create a VLAN subinterface to capture untagged traffic on a mixed tagged/untagged port.
So… is this possible yet in 4.x (not using vlan-id=0, but the ability to split/separate out untagged from tagged traffic)?
If not, is there any chance of a feature like this (probably easiest to do it with a vlan-id=0 hack) in future versions?
Thanks!
Aaron out.
