Hello guys,
I started to investigate one specific issue. Topology as depicted
The following is the configuration of the: UPLINK MIKROTIK (2011UiAS-2HnD)
add admin-mac=4C:5E:0C:43:DE:F6 arp=proxy-arp auto-mac=no mtu=1500 name=bridge-local vlan-filtering=yes
/interface vlan
add interface=sfp1-gateway name=vlan1 vlan-id=1
add interface=sfp1-gateway name=vlan357 vlan-id=357
add name=dhcp ranges=192.168.168.50-192.168.168.240
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=vlan1 name=dhcp1
add bridge=bridge-local hw=no interface=ether2
add bridge=bridge-local hw=no interface=ether3
add bridge=bridge-local hw=no interface=ether4
add bridge=bridge-local hw=no interface=ether5
add bridge=bridge-local hw=no interface=ether6
add bridge=bridge-local interface=wlan1
add bridge=bridge-local hw=no interface=sfp1-gateway
add bridge=bridge-local interface=ether7
add bridge=bridge-local interface=ether8
add bridge=bridge-local interface=ether9 pvid=357
add bridge=bridge-local interface=ether10
/interface bridge vlan
add bridge=bridge-local tagged=sfp1-gateway vlan-ids=1
add bridge=bridge-local tagged=sfp1-gateway vlan-ids=357
Next, I have this config for the (962UiGS-5HacT2HnT)
add fast-forward=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=sfp1 name=vlan1 vlan-id=1
add interface=sfp1 name=vlan357 vlan-id=357
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
add bridge=bridge1 interface=ether4 pvid=357
add bridge=bridge1 interface=sfp1
add bridge=bridge1 tagged=sfp1 untagged=ether1,ether2,ether3,ether5 vlan-ids=1
add bridge=bridge1 tagged=sfp1 untagged=ether4 vlan-ids=357
When I tested this configuration in my lab everything works well. When I run two DHCP servers on the uplink mikrotik I’m able to get network parameters from two different DHCP servers (server1 vlan1 and server2 vlan357 = just in LAB for testing purposes)
Then I sent the (962UiGS-5HacT2HnT) MK to production and I noticed weird behaviour of the network. I cannot obtain DHCP parameters from DHCP server. Neither from ACCES 1 or ACCESS 357 ports. With the help of packet sniffer I’m able to see DISCOVER mesages from the clients and these messeges get to the DHCP server. DHCP server then send OFFER down to the trunk port and I can see the messeges through packet sniffer on the bottom mikrotik. But when I run wireshark on client machines there is no offer.
The topology looks simple but I have already tried everything and still can’t get this topology to work correctly.
Any ideas? Thanks for any help.
