Hi, i have a very simple configuration, i just need only one trunk port. (24) and the other ports (1 - 23) are VLANs ports . Then in every port, i need run pppoe-clients, but this isn’t happening. I can watch the pppoe-discovery with torch in the server in the other side (tourch in vlan) but the pppoe-session never has success.
This is my configuration:
set [ find default-name=sfp1 ] master-port=ether24
set [ find default-name=ether1 ] master-port=ether24
set [ find default-name=ether2 ] master-port=ether24
set [ find default-name=ether3 ] master-port=ether24
set [ find default-name=ether4 ] master-port=ether24
set [ find default-name=ether5 ] master-port=ether24
set [ find default-name=ether6 ] master-port=ether24
set [ find default-name=ether7 ] master-port=ether24
set [ find default-name=ether8 ] master-port=ether24
set [ find default-name=ether9 ] master-port=ether24
set [ find default-name=ether10 ] master-port=ether24
set [ find default-name=ether11 ] master-port=ether24
set [ find default-name=ether12 ] master-port=ether24
set [ find default-name=ether13 ] master-port=ether24
set [ find default-name=ether14 ] master-port=ether24
set [ find default-name=ether15 ] master-port=ether24
set [ find default-name=ether16 ] master-port=ether24
set [ find default-name=ether17 ] master-port=ether24
set [ find default-name=ether18 ] master-port=ether24
set [ find default-name=ether19 ] master-port=ether24
set [ find default-name=ether20 ] master-port=ether24
set [ find default-name=ether21 ] master-port=ether24
set [ find default-name=ether22 ] master-port=ether24
set [ find default-name=ether23 ] master-port=ether24
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1,ether24 vlan-id=1
add tagged-ports=ether2,ether24 vlan-id=2
add tagged-ports=ether3,ether24 vlan-id=3
add tagged-ports=ether4,ether24 vlan-id=4
add tagged-ports=ether5,ether24 vlan-id=5
add tagged-ports=ether6,ether24 vlan-id=6
add tagged-ports=ether7,ether24 vlan-id=7
add tagged-ports=ether8,ether24 vlan-id=8
add tagged-ports=ether9,ether24 vlan-id=9
add tagged-ports=ether10,ether24 vlan-id=10
add tagged-ports=ether11,ether24 vlan-id=11
add tagged-ports=ether12,ether24 vlan-id=12
add tagged-ports=ether13,ether24 vlan-id=13
add tagged-ports=ether14,ether24 vlan-id=14
add tagged-ports=ether15,ether24 vlan-id=15
add tagged-ports=ether16,ether24 vlan-id=16
add tagged-ports=ether17,ether24 vlan-id=17
add tagged-ports=ether18,ether24 vlan-id=18
add tagged-ports=ether19,ether24 vlan-id=19
add tagged-ports=ether20,ether24 vlan-id=20
add tagged-ports=ether21,ether24 vlan-id=21
add tagged-ports=ether22,ether24 vlan-id=22
add tagged-ports=ether23,ether24 vlan-id=23
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=1 ports=ether1 sa-learning=yes
add customer-vid=0 new-customer-vid=2 ports=ether2 sa-learning=yes
add customer-vid=0 new-customer-vid=3 ports=ether3 sa-learning=yes
add customer-vid=0 new-customer-vid=4 ports=ether4 sa-learning=yes
add customer-vid=0 new-customer-vid=5 ports=ether5 sa-learning=yes
add customer-vid=0 new-customer-vid=6 ports=ether6 sa-learning=yes
add customer-vid=0 new-customer-vid=7 ports=ether7 sa-learning=yes
add customer-vid=0 new-customer-vid=8 ports=ether9 sa-learning=yes
add customer-vid=0 new-customer-vid=9 ports=ether9 sa-learning=yes
add customer-vid=0 new-customer-vid=10 ports=ether10 sa-learning=yes
add customer-vid=0 new-customer-vid=11 ports=ether11 sa-learning=yes
add customer-vid=0 new-customer-vid=12 ports=ether12 sa-learning=yes
add customer-vid=0 new-customer-vid=13 ports=ether13 sa-learning=yes
add customer-vid=0 new-customer-vid=14 ports=ether14 sa-learning=yes
add customer-vid=0 new-customer-vid=15 ports=ether15 sa-learning=yes
add customer-vid=0 new-customer-vid=16 ports=ether16 sa-learning=yes
add customer-vid=0 new-customer-vid=17 ports=ether17 sa-learning=yes
add customer-vid=0 new-customer-vid=18 ports=ether18 sa-learning=yes
add customer-vid=0 new-customer-vid=19 ports=ether19 sa-learning=yes
add customer-vid=0 new-customer-vid=20 ports=ether20 sa-learning=yes
add customer-vid=0 new-customer-vid=21 ports=ether21 sa-learning=yes
add customer-vid=0 new-customer-vid=22 ports=ether22 sa-learning=yes
add customer-vid=0 new-customer-vid=23 ports=ether23 sa-learning=yes
add ports=ether1,ether24 vlan-id=1
add ports=ether2,ether24 vlan-id=2
add ports=ether3,ether24 vlan-id=3
add ports=ether4,ether24 vlan-id=4
add ports=ether5,ether24 vlan-id=5
add ports=ether6,ether24 vlan-id=6
add ports=ether7,ether24 vlan-id=7
add ports=ether8,ether24 vlan-id=8
add ports=ether9,ether24 vlan-id=9
add ports=ether10,ether24 vlan-id=10
add ports=ether11,ether24 vlan-id=11
add ports=ether12,ether24 vlan-id=12
add ports=ether13,ether24 vlan-id=13
add ports=ether14,ether24 vlan-id=14
add ports=ether15,ether24 vlan-id=15
add ports=ether16,ether24 vlan-id=16
add ports=ether17,ether24 vlan-id=17
add ports=ether18,ether24 vlan-id=18
add ports=ether19,ether24 vlan-id=19
add ports=ether20,ether24 vlan-id=20
add ports=ether21,ether24 vlan-id=21
add ports=ether22,ether24 vlan-id=22
add ports=ether23,ether24 vlan-id=23
Seems like something is filtering the pppoe-session througth the vlan. Has had somebody the same trouble?
Thanks!
